I am getting my taxes here soon :D and have my mind set on a Comanche.
I decided NOT to go with what I've grown up on, a '85 Toyota. I hope I am making the right choice :dunno:
Iv'e been doing the research on what to look for and what avoid. I have been looking for a good manual as I know I'm going to have to turn the wrench a lot initially. What are you guys recommending?
I have both Chiltons and Haynes. I like the Haynes more because it cross references to other steps to perform when you are repairing/replacing parts. The Chiltons just states "remove X...reinstall X." But, I refer to both when I start to work on something I am not familar with (which is a lot.)
I searched and found a Factory Service Manual (FSM) online that (supposedly) covered "84 - 87 Comanches". The years had me concerned, since the MJ started in 86.
I bit the bullet and bought the FSM. Upon looking it over, it only covered the 86 models. It did not have any info about 4.0 eng. or BA10/5 trans. I returned it and got a full refund.
I found a FREE Factory Service manual to years but it says 84-93... It sounds kinda weird but i downloaded it and it seems like a good manual. It has the 4cyl, V6, and 4.0 engines. its like a 366 page manual in PDF form.
Can I post a 27meg file on a forum? Id be happy to show everyone what it looks like.
FSM. Only way to go. But each manual only covers one year. I have one for the '86, '88, 89 and 91. Pretty well covers everything.
Chilton and Haynes are pretty good for reference.
I have the 89 FSM set. Came with 4 books. I would try to find one on Ebay, I waited and got mine for a great price in near perfect shape.
87-90 should be the same. Except for the tranny section. My 89 set has a seperate book for the ax15 and the 90 should have ax15 info while the 87-88 should be the peugeot
What do the covers look like? Where did you purchase them from? (More than just ebay.)
I also think that the FSM is the very best manual to use. They're not
cheap (like auto store manuals) but I've found them worth their weight
in gold for level of accurate detail. My OEM two volume set for 1992 cost
me about $75.00. I keep them behind the driver seat.
The original MR 277 just covered the '86 MJ. first published in July '85. What the seller on ebay has done was take the '85, '86, '87 '88 manuals and combine them. Personally I think it's a good deal. Saves buying 4 seperate books and covers the range. The one advertised as covering '84-'87 covered both MJ and XJ. This one just covers the MJ.
The one marked 84-87 had nothing about the 4.0 or BA10/5 (not that I would open up a trans).
I think I might contact the seller with questions and concerns.
You want the one that looks like this. All years look the same, just different colors.
http://www.ebay.com/...erature&vxp=mtr
Read the description close, some will show a pic of the book but it is actually a CD. Most have a book for engine, chassis, and body, and a seperate electrical manual. My 89 set also had two more books, one for the ax15 and one for the abs system.
Awesome. I just grabbed one off e-bay. Maybe it will help with my brake lights!
Which ones did you order - the one volume or two volume? Let me know what you think of them...before I purchase again.
BTW, what's the detail on your MJ?
Keep an eye out at the swap meets too. There is always a huge booth with a ton of books. Ask them where thee Jeep stuff is. Usually, he's going to walk to the back, dust off a forgotten crate, and let you pick through. I've bought a handful locally this way. No shipping, face to face haggle. They always seem to be willing to move the lesser Jeep stuff in favor for room of others... Also, keep a sharp eye out at the junkyard. I was rifling through an XJ once and stumbled upon an FSM. I brought it up with me and put it on the counter. The guy just looked at it, looked at me, and said "Big @$$ owners manual, $5". I kept my mouth shut and gave the man my money.
Rob :D
Anyone that has an 87-90 Renix
I recommend the 1989 set.
Very complete, and well laid out.
91-92 HO, get either the 91, or 92 books
The problem is with the 86's.
One thing Chrysler did better than AMC was its FSM's.
AMC would put out a main manual to cover the body,
then each major component had its own smaller manual.
So if you have an 86' MJ w/ a 2.8L & an AX-5,
you'd need the brown, main MJ book + the 2.8L & AX-5 books.
^^^my recommendation would be to get those + the 1989 Chrysler set
(Chrysler bought AMC in 87', but took till model year 1989' to revise the manuals.)
OCD - obsessive compulsive disorder :yes:
You say that like its a bad thing ;)
That pic is about half of the Jeep literature collected over the years.
Jeep stuff was literally 'throw away' material (slightly better than "Renault stuff") for the AMC guys years ago.
One awesome AMC vender would put all the Jeep stuff he'd end up with throughout the year aside in a big box for me.
Then hit me with a very fair all-or-nothing "Jim's Jeep Box Price" when I'd see him.
Ended up with some very interesting stuff from that guy (thanks Jesse!!!)
The rest were picked up on Ebay & car shows for $5-30 each before FSM prices went insane.
jpnjim,
Let me write you a prescription for your ocd.
1. purchase a scanner. It should have a document feeder with dual sided scanning.
2. remove the binding from the books. beginning with the ones for the '87s,
3. get yourself an adult beverage.
4. begin scanning.
5. send me the files to review.
6. repeat as necessary.
I'll host any and all manuals on my server for you. We can password protect them, and only PM the password to members on here.
I picked the combined service manual on CD. Id rather have the paper ones, but the item description said it is a PDF. I figure I can get it printed and bound at Staples if I find myself using it a lot.
http://www.ebay.com/itm/370395031922?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
