sinkrun Posted December 15, 2012 Share Posted December 15, 2012 Does anyone know whats involved in putting a 98 4.0 engine in a 2001 xj. Whats the differances in electronics etc. Link to comment Share on other sites More sharing options...
Backdraft Posted December 15, 2012 Share Posted December 15, 2012 The 98 will have a distributor, the 01 will be coil on plug. Link to comment Share on other sites More sharing options...
valis Posted December 15, 2012 Share Posted December 15, 2012 I did this exact swap on my '01XJ after spinning a rod bearing on the original engine. The swap is extremely easy IF you have an adapter plate to go from the larger intake/exhaust ports on the '98 engine to the smaller ports on the '01 two-piece cast manifold. Adapter plate can be seen here: Pull the dizzy out of the hole and drop the camshaft position sensor...just make sure it's set correctly and isn't 180 degrees out like I did the first time around :yes: Some of the '98 sensors may have different connector plugs, so you'll need to steal the sensors from the '01 engine. Link to comment Share on other sites More sharing options...
sinkrun Posted December 15, 2012 Author Share Posted December 15, 2012 IS the plate something you made or bought? Link to comment Share on other sites More sharing options...
dfreeman616 Posted December 16, 2012 Share Posted December 16, 2012 there's a guy on naxja who sells them here's the page http://naxja.org/forum/showthread.php?t=919384 and he provides his email his email wilsmick@gmail.com if i don't make my own plate i'll be getting ahold of him shortly. Link to comment Share on other sites More sharing options...
sinkrun Posted December 16, 2012 Author Share Posted December 16, 2012 Thanks great info and after I read to the end there only 100.00 now instead of 150.00. Link to comment Share on other sites More sharing options...
valis Posted December 16, 2012 Share Posted December 16, 2012 I bought mine from the previously mentioned seller. Link to comment Share on other sites More sharing options...
Sir Sam Posted December 16, 2012 Share Posted December 16, 2012 why is this needed? When I went the other way, 01 engine into a 96, I just bolted up the 96 intake to the 0331 head. Link to comment Share on other sites More sharing options...
valis Posted December 16, 2012 Share Posted December 16, 2012 The exhaust ports on the 00-01 header are so much smaller than the non-0331 exhaust ports that it won't completely cover them up. Link to comment Share on other sites More sharing options...
Sir Sam Posted December 16, 2012 Share Posted December 16, 2012 ah, copy that. Link to comment Share on other sites More sharing options...
sinkrun Posted July 25, 2013 Author Share Posted July 25, 2013 Sorry to bring up a old thread however it took this long to blow the 2000 XJ engine. I found a decent 96 can the above procedures be used with the 96? Link to comment Share on other sites More sharing options...
dfreeman616 Posted July 27, 2013 Share Posted July 27, 2013 yes Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 27, 2013 Share Posted July 27, 2013 Thinking too hard. If your 01 has split manifolds, but no pre-cat, swap to the 98 exhaust manifold and y-pipe, using the 01 o2 sensor. problem solved. Link to comment Share on other sites More sharing options...
randomguy310 Posted August 3, 2013 Share Posted August 3, 2013 what do you do about the coil pack bolting on? Link to comment Share on other sites More sharing options...
sinkrun Posted August 3, 2013 Author Share Posted August 3, 2013 I used this guys idea, http://www.naxja.org/forum/showthread.php?t=937214 and I did put it in runs great mine did have pre cats so I just used the adapter. Link to comment Share on other sites More sharing options...
valis Posted August 3, 2013 Share Posted August 3, 2013 I've gone over 60K miles in 4+ years without the coilpack bolted on. Link to comment Share on other sites More sharing options...
randomguy310 Posted August 5, 2013 Share Posted August 5, 2013 ok, thanks Link to comment Share on other sites More sharing options...
