97+ Additional Factory Switches.
So...I need more switches in my xj. Trying to come up with a new switch location, I was befuddled. I want 3 more factory rocker switches...and had been thinking of utilizing the garage door opener location in my overhead console.
Once in there, I realized that it was nowhere deep enough to fit the switches....you could get the switches in that area and have them be level, but it wasn't deep enough to add connectors, too. I could hack out the backing of the OHC, hog another hole in the headliner behind it, and do that...but then I still have to run a ton of wires. Just not my cup of tea.
Looking on ebay, I came across this...
http://www.ebay.com/itm/Jeep-Wrangler-TJ-Upper-Dash-Switch-Panel-Only-Free-Slappy-Pad-/130778310085?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AWrangler&hash=item1e72fea5c5&vxp=mtr
and thought "neat...don't like aftermarket switches, but neat"
so...I decided to try something. I don't have process pics, and it's not quite done, and I'm not entirely sold on the idea... I may keep this idea, I may find somewhere else. who knows?
started with a factory 3 switch bezel that had a bad lighter outlet, and a crack in the mount...combine that with a factory vent, and "presto"
I did that using a plastic welder, a metal file, and a scuff pad. It's not done. I will have to either weld in more plastic on a few low spots and resand, or just use some body filler, sand it smooth, then vinyl dye it charcoal.
the area the plugs are in is very accessible, you can run wires in without pinching them and without cutting up the vent in case you want to go back to stock. It doesn't look stock, but doesn't look horrible IMHO.
I will obviously be buying different switches for it... a simple backlit "ON" switch, one more replacement "fog" switch, and a "RL" switch for the beefy in-bumper reverse lights I will be installing for plowing purposes.
The point is factory looking switches to do 3 things: turn on the slik stick plow control, flip the headlights from factory function to upper lights, and transfer reverse light functioni from the factory tails to the fogs that will be in the back.
This is the supplier I will be using. I'm running one of his fog light switches now, they are considerably beefier internally than stock, which gets rid of the issue of frying out switches all the time. He has many variances available.
http://www.ebay.com/itm/300814002573?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Much appreciated Don, but I want nothing to do with aftermarket switches, or metal panels, or any of the locations he puts things in...I like my ash tray, it holds my business cards, cd player remote, etc.
Remove the windshield. replace it with a metal panel. This should give you all the mounting space you will ever need to mount switches, gauges or anything else you might want.
Hornbrod pointed me to a set of those straight from the UK. I just couldn't afford to do the $100 Jeepsrus new one... I'm too cheap. The one Don had found for me even came with all the switches, including the headlight leveling switch.
Rob
Jim, it's out of an XJ. Either a domestic XJ in police trim with fogs would have it, or a euro spec XJ with headlight leveling function. Both need the 4th slot for the extra switch.
Fogs
Rear Defrost
Rear Wiper
And either:
Ext Idle (Up idle switch for US police spec Cherokee's)
Headlight Leveling (Euro spec option)
Rob
Rob
Damn. That looks familiar.
The nice thing about that is you get two different fog light switches, the euro XJ rear fogs have a similar, but different switch so you can tell them apart.
I'm going to be using he same thing in my MJ, but without a rear wiper I will have one extra switch, and if I don't have heated mirrors(which I would like) I will have 2 extra's......
Someone point me to where one could find a set of the four switch panel? I am having trouble finding a good, but not expensive source. I saw one on eBay, once.
I want one with four switches since Air On Board makes nice factory style switches to pop in there.
http://www.ebay.com/itm/Rocker-switch-330-12-volt-Front-diff-locker-OFF-Jeep-Wrangler-1997-2006-/261127846281?hash=item3ccc6eb989&item=261127846281&pt=Motors_ATV_Parts_Accessories&vxp=mtr
Someone on another forum had just put one in, and I asked him where he picked it up. He had got his from jeepsareus, but had to pay the $100 for it. I had looked on eBay to no avail... I tried all sorts of searches and keywords too. I sent Don a message since he's pretty good at helping find the weird items. He turned one up on eBay I had missed, and found the jeepsareus one also. Even was able to tell me the PN for the dealer part. I paid a bit more than I wanted for the one on eBay, but it was still less than the $100, and it came with the switches in the pic.
When I get home, I can send you the seller info for the one Don found for me. They seem to be a dismantler in the UK.
Rob
there is a breaker in the Uk that I buy my parts from. probably the same one that automan is going to tell you about. We will see if he comes through.
First time dealing with him, but it was very pain free and smooth. Hardest part was converting pounds to dollars so I knew what I was spending... And remembering to hit the pounds button on the paypal. Good guy.
Rob
For a dash electric fuel pressure gauge I've had forever and never mounted. Plastic surgery like you have done has given me an idea w/o doing the Autometer A-pillar dual gauge pod. :thumbsup:
