ftpiercecracker1 Posted November 17, 2012 Posted November 17, 2012 This is a quick writeup for adding a newer model rearview mirror to your MJ. Just as a forewarning you have to remove your headliner to do this properly Ok here we go . . . Unfortunately i did not take note of where i got this mirror except it was from a PnP. Image Not Found This particular mirror has three wires. . . Orange, Black, and White Orange will be a Constant hot. Black your Constant ground White is a switched ground, door open / lights on, door closed / lights off In this picture you can see where i have fed the wires up as to keep them out of the way and consolidated. Also you can see what to do with the BLACK wire in this picture as well. Use a VERY short self tapping screw. You can use a round wire crimp or do what i did and strip a whole bunch of the wire back and wrap the bare copper wire around the screw shaft. IF you have working vanity mirrors, this makes things much easier. Take the orange wire and splice into the hot vanity wire, simple as that. * If you don't have vanity mirrors you will have to find a source for you hot, possibly the radio, which will require significantly longer wire to be run, but still 100% doable. Next its time for the Switched ground, white wire. . . Ignore the second black wire, you will only need one. The wire you decide to use will need to be long enough to run along the roof to the Passenger side A pillar, down the A pillar and into protective plactic cover at the bottom. Now that you have the wire run you need to tap into your Floor board light harness. There will be two wires going to the bulb, a red/pink one and a black one. Splice the wire you have just run into the BLACK wire. After this, test it out see if everything works. Function, Door open both map lights will come on together. Door closed lights go off, BUT you will be able to turn them both on individually. If it works, tuck everything back in, glue your new mirror in place and your done. P.S. Store bought super glue actually works pretty good.
Comanche County Posted November 19, 2012 Posted November 19, 2012 Good idea, looks pretty easy. This is one of those things I've always wanted to do.
ftpiercecracker1 Posted November 20, 2012 Author Posted November 20, 2012 Yup once you know how its done its Really easy, i tried following the first writeup on here and got lost, didnt have the same setup, or something like that. If you get lost following the writeup PM i would be happy to offer assitance.
HOrnbrod Posted November 20, 2012 Posted November 20, 2012 I had that same map light mirror mounted for awhile, but with the under-dash courtesy lights, the LED B-pillar lights, and vanity sun visors, I was overwhelmed with excess cab lighting. So I swapped out the map-light mirror with a Home Link auto-dimming rear view mirror I pulled at the yard. Much more usefull opening either garage door and/or unlocking the house entrance door. Plus the auto-dimming feature is great at night when some turkey behind you is running high beams.
Mountain Dude Posted November 20, 2012 Posted November 20, 2012 If you don't connect the ground wire to the door switches, they can still be used as map lights but won't come on with the rest of the in cab lights.
HOrnbrod Posted November 20, 2012 Posted November 20, 2012 Of course. But I quit using hard copy maps long ago. So who needs map lights?
Comanche County Posted November 20, 2012 Posted November 20, 2012 Improved lighting (interior and exterior) for the MJ has been on my mind for a long time. I'm still gathering data and learning. I want some super headlights with high beams that are comparable to the best modern high beams. But I hate those ultra bright white and blue beams. Hate getting blinded by those. Then for extra offroad lights I want something like the tight beams of KC Daylighters, then another pair of forward offroad lights for flood. Something for under the hood switched on demand, also some flood lights under the MJ for night wheeling. For the interior, something like Cracker's that's tied into the door switches, but also lighted vanity mirrors in the visors. I also want improved B Pillar lights but I want them to look stock. Oh, and I want it all to be low amp draw like LEDs......but I don't want to spend 2K for Baja style lighting. This will require a lot more switches and relays. I want the switches high on the headliner. So whenever I get around to glassing my headliner and installing some sort of upper console and have a good cost effective plan for the rest of the interior and exterior lighting (and I have the $), then I want to do it all as one project. I have an endstate in mind, just not sure how to get there without going power shopping.
neohic Posted November 20, 2012 Posted November 20, 2012 Improved lighting (interior and exterior) for the MJ has been on my mind for a long time... This will require a lot more switches and relays. I want the switches high on the headliner.... Yeah... everyone wants more lighting and running enough power can be an issue. ... always know where your switches are.
