ftpiercecracker1 Posted November 17, 2012 Share Posted November 17, 2012 I am using the HO Fuel rail, which means i have to use the longer HO fuel lines, Can i just get a complete set from a donor? Rail to tank. EDIT: i just had a thought, I think the only way it would work would be if i found an HO comanche, Cherokee has the fuel tank in a different location. Sooo how would one make the HO fuel rail work, if you can't find an HO comanche? Link to comment Share on other sites More sharing options...
jimoshel Posted November 17, 2012 Share Posted November 17, 2012 Splice the fuel lines? Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 17, 2012 Author Share Posted November 17, 2012 How? :hmm: Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 18, 2012 Share Posted November 18, 2012 Cut a section of the fuel line out along the frame rail and splice a length of 5/6 steel tubing to make the distant end long enough. Double flare each end (like a brake line), and use flare unions to connect it all back up. Single flares will work just fine too. They are more secure than the factory quick connectors. Link to comment Share on other sites More sharing options...
JENSSEN Posted November 18, 2012 Share Posted November 18, 2012 A compression union will also allow you to splice pressure lines together,... Link to comment Share on other sites More sharing options...
darkenfire Posted November 19, 2012 Share Posted November 19, 2012 Cut a section of the fuel line out along the frame rail and splice a length of 5/6 steel tubing to make the distant end long enough. Double flare each end (like a brake line), and use flare unions to connect it all back up. Single flares will work just fine too. They are more secure than the factory quick connectors. That is definitely the best way to do it. I just got done putting my '95 cherokee HO in my comanche, though, and I mickey moused it a bit. Much easier, haha. here's what I did: (talking about the cherokee fuel lines here) Pulled the lines off the engine Right at the engine its soft line, then it turns into hard line, and turns back into soft line near the tank. Next the tranny the hard line is really straight and runs along the frame rail, I cut there using a tube cutter. Just cut wherever you think you'll have the most access. Flare the ends where you cut it with a flaring tool since the hard line is now flared, you can get soft fuel line by the foot from the auto parts store, and hose clamp it on right behind the flare without worries run soft line from your cut to the comanche fuel filter (replace it while you're at it) for the in line, and the whole way to the comanche tank for the return line. My comanche tank and pump are running the HO just fine. zip tie everything in place ... voila Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 20, 2012 Author Share Posted November 20, 2012 That is definitely the best way to do it. I just got done putting my '95 cherokee HO in my comanche, though, and I mickey moused it a bit. Much easier, haha. here's what I did: (talking about the cherokee fuel lines here) Pulled the lines off the engine Right at the engine its soft line, then it turns into hard line, and turns back into soft line near the tank. Next the tranny the hard line is really straight and runs along the frame rail, I cut there using a tube cutter. Just cut wherever you think you'll have the most access. Flare the ends where you cut it with a flaring tool since the hard line is now flared, you can get soft fuel line by the foot from the auto parts store, and hose clamp it on right behind the flare without worries run soft line from your cut to the comanche fuel filter (replace it while you're at it) for the in line, and the whole way to the comanche tank for the return line. My comanche tank and pump are running the HO just fine. zip tie everything in place ... voila I like :yes: , mickey mousing and all Link to comment Share on other sites More sharing options...
