AMC 20
I found an AMC 20 (I hope, it looks like one to me) under a 86 MJ XLT longbed out in the local yard to replace the Dana 35 mine has now, got the whole rear end, leaf springs and every thing for $200.
Can any of the Guru's on the board confirm that this is a 3.55 ratio from the markings on the back of the diff? I have read in various places the big 'N' might be 3.55 and a trac-lock, or am I looking in the wrong place?
Sorry about the cell phone picture as you try to diagnose this.
Thanks a bunch if anyone can confirm these suspicion's of mine.
Do any of you suggest I go back and pick up anything else for this to fit perfect, or do I have the most important stuff? Oh yea the drive shaft had been bent when they put it in the yard so I'll have to wing it there.
Thanks again
Andy
Do you know what engine and transmission were in the truck? It seems unlikely that it would have been a 3.55. That ratio was used only behind early 4-cylinder 4-speeds. It's more likely to be a 3.73 or a 4.10. (I think).
Eagle
It was from a V6 2.8L I didn't look at the Trans real close so I'm no help there.
carnuck
I will look for the stampings when i clean off the years of stuff maybe this weekend, I'm hoping that i find something.
Most likely what mjeff87 said willl happen, when time is avalible so this might just be the way i find out for absolutly sure.
Thanks all for the info
Andy
