86 Rough Idle Fix 2.5
hey guys just printed this off today at school off of all data thought some might appreciate it since all do not have access to all data. hope this helps.
ill try and post some real pics when i try this hopefully soon
also anyone know how to post a pic so it just shows up so you don't have to follow a link?
Simply put image tags before and after the complete pic address. Then your pictures comes up like so:
ok just did this....so step one
1. remove the three little nuts holding on this thing...no idea what its called hahah
2. there is a stud on the intake manifold that has a bracket holding the hose from the pcv valve you may need to remove a nut (i didnt) slide the bracket up over the stud so it hangs loose
3 there will be a rubber connector thing which u can see in the other pictures pull that off.
4. replace with individual tubes
5.re assemble don't forget to plug the wiring harness back on to the thingy you had to remove
