big66440 Posted November 14, 2012 Share Posted November 14, 2012 My steering coupling on the steering column directly under the brake booster is slipping bad, I don't want to drive my truck this way I've read about different ways to fix this problem what would you guys recommend? I have access to a welder if it helps. Link to comment Share on other sites More sharing options...
cody4359 Posted November 14, 2012 Share Posted November 14, 2012 i think your talking about the steering linkage to gearbox? buy a new one :dunno: if I'm wrong a picture might help Link to comment Share on other sites More sharing options...
big66440 Posted November 16, 2012 Author Share Posted November 16, 2012 Nevermind, I fixed it it was the steering linkage (the rubber piece with the steel sleeve )that went bad I drilled a hole all the way through and put a bolt an nut. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 16, 2012 Share Posted November 16, 2012 Rubber piece? :hmm: Link to comment Share on other sites More sharing options...
Eagle Posted November 17, 2012 Share Posted November 17, 2012 Nevermind, I fixed it it was the steering linkage (the rubber piece with the steel sleeve )that went bad I drilled a hole all the way through and put a bolt an nut. Huh? ??? Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 17, 2012 Share Posted November 17, 2012 Huh? ??? same here.. . :hmm: Link to comment Share on other sites More sharing options...
big66440 Posted November 21, 2012 Author Share Posted November 21, 2012 Lol, look at the steering shaft that comes out of the firewall directly under the brake booster there's a rubber coupling piece,the outer sleeve (made of steel) was slipping, I drilled a hole all the way through the steering shaft and put a bolt and nut to keep it from slipping. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 21, 2012 Share Posted November 21, 2012 Like a rubber boot? Link to comment Share on other sites More sharing options...
