T Case Bomb
Hello,
This transfer case is chain-driven and aluminum-housed.
If you have the I6 and were doing anything halfway strenuous, and if the transfer case had any major mileage on it, the chain either let go (which, according to your profile pic, it's intact), or stretched to the point it came off and cracked the housing.
I'm almost wondering if the houseing cracked first, though, due to excessive torque.
Remember, these were designed around driving on snowy streets, not mudding.
How was your chain deflection prior to this?
Regards,
Josh
Did the mounts all hold? It is sounding more like the aluminum housing let go because of torque -- or because of a flaw in the aluminum casting.
If you weld 'er up, make double danged sure of all the bearings, of course. You lost fluid and it doesn't take a whole heck of a lot to score the bearings for eventual lockup and failure. Don't want to do this job a third time, man!
Josh
If you have mods to the front axle causing the front driveshaft to always spin when in motion (locker, single shaft conversion, non disconnect axle etc.), the most common cause for that is the double cardan joint on the front driveshaft locking up from lack of lubrication.
The 2wd section looks like it's all in tact so my guess would be something was binding and caused the 4wd section to rip off. What you say it only has 5k miles on it, was it a rebuilt? A bearing not being fully seated could cause something like this to happen.
I've seen a case that blew up like that once before in person. The issue with that case was that something in the front drive shaft let loose and snapped the end off of the transfer case.
  • 1 month later...
I saw this tcase pic from your other thread.
If you were just cruising down the highway,
it probably.didn't break from contact, or the ft shaft bottoming out.
Weird.
Could it be possible something didn't go back in right on the recent rebuild?
Did it bind when turning on pavement in 2wd,
or did it turn freely like it should?
Any chance it was accidentally left in 4wd on pavement for a long trip?
