Eagle Posted November 4, 2012 Share Posted November 4, 2012 $75 later, I can adjust the toe-in on the "new" (to me) 2001 Cherokee. Tie rod adjusting sleeve was so badly rusted to the TREs that I put the longest pipe wrench I have on it, stood on it with my current 240 pounds and bounced ... and it wouldn't move. Finally did a preemptive strike. Replaced both TRE's and the long sleeve, and I can finally adjust the toe-in. It's nice to be able to steer again. Link to comment Share on other sites More sharing options...
Comanche County Posted November 5, 2012 Share Posted November 5, 2012 Same thing on my drag link. I tried to replace the ends but they're rust welded. I took it to a machine shop and they put in in a pipe threader which put a couple thousand lbs of pressure and it still wouldn't budge. Just spun and gouged the drag link. I'll get a pic in the morning. Link to comment Share on other sites More sharing options...
valis Posted November 5, 2012 Share Posted November 5, 2012 I can think of at least five Jeeps I've attempted to adjust the tie rod and drag links to correct steering issues. All five required replacement of all components. It's a nice design when it works as it makes it incredibly easy to do the alignment but it doesn't take long for water, sand, salt, mud, and dirt to get into the gap in the adjustment sleeves and in between the low profile fine threads of the TRE's. Link to comment Share on other sites More sharing options...
knever3 Posted November 8, 2012 Share Posted November 8, 2012 There is a specific tie rod adjustment tool that various companies like OTC make that attach to a wratchet and are shaped like a C. They pry open the sleeve while adjusting it instead of a pipe wrench that crushes the sleeve while trying to adjust it. I always clean out the sleeve because it's clogged with dirt, spray pennetrant on it and if it still doesn't move use some heat. The thing to remember when using heat during an alignment is to always wait till it's cold to get proper measurments. Link to comment Share on other sites More sharing options...
Automan2164 Posted November 8, 2012 Share Posted November 8, 2012 I've used those tie rod hooks before... Work like a charm. Harbor Freight even has some now: http://www.harborfreight.com/5-piece-tie-rod-pitman-arm-adjustment-set-66796.html Rob Link to comment Share on other sites More sharing options...
Pete M Posted November 8, 2012 Share Posted November 8, 2012 neat! Link to comment Share on other sites More sharing options...
valis Posted November 8, 2012 Share Posted November 8, 2012 Cool. Gonna add those to the x-mas wishlist! Link to comment Share on other sites More sharing options...
