Alexia Posted October 27, 2012 Posted October 27, 2012 What are these two lines I am pointing at? The secondary rear brake return line has been pulled to the side already and is out of the picture. Fuel is to the right next to the brake booster.
RDAN1 Posted October 27, 2012 Posted October 27, 2012 IIRC, the upper one in the pic looks like it is the gas tank vent line going to the charcoal canister. The other one looks like it was a flex fuel line with the end cut off of it.
ftpiercecracker1 Posted October 27, 2012 Posted October 27, 2012 I know the one with the fabric wrap is a clutch hydralic line with the fitting cut off, the other i am about 95% sure goes to the vacuum ball under the front bumper Edit: I think I'm wrong about the vacuum ball, sounds like RDAN1 is on the right track.
Alexia Posted October 28, 2012 Author Posted October 28, 2012 IIRC, the upper one in the pic looks like it is the gas tank vent line going to the charcoal canister. The other one looks like it was a flex fuel line with the end cut off of it. Thanks! I can definitely reuse that then for the 1997 under hood charcoal canister. I know the one with the fabric wrap is a clutch hydralic line with the fitting cut off, the other i am about 95% sure goes to the vacuum ball under the front bumper Edit: I think I'm wrong about the vacuum ball, sounds like RDAN1 is on the right track. Time to get yank happy with that line then. Automatic transmission is going in so I definitely do not need it.
