Huck731's 91 Mj Daily Driver
today finally marks the start of me fixing the clutch slave cylinder....a part I have had for about 3 weeks now. the topper is also coming off so I can get the truck on my garage. still undecided if it will be going back on though.
  • Replies 117
I got the topper off today along with the garage cleaned so I can get her in there. I'm going to attempt to drive it to work tomorrow based on the sole fact that it gets alot better fuel mileage that a 95 chevyt 1500 Z71.
Idle speed controller motor ....
His 91 has the Chrysler multipoint fuel injection system not the renix throttle body system, therefore no Idle Speed Control Motor. Instead, it will have an Idle Air Control Valve (IAC) which is a plunger style device that can usually be cleaned.
clutch job is finished. with the help of my stepdad and uncle the lend a few extra hands and tell me what to do, the new clutch was installed and the truck back together in right around 4.5 hours. that makes me wonder why it takes the "pro's" at the dealership 4 hours and this was the first time I have ever done a clutch and slave cylinder. what size/type of bit do I need to get the trans fluid fill/check hole open?
well the new clutch/slave combo seem to be working just fine. my next investment will probably be new rear u-joints as my uncle said they are starting to show signs of going bad (I trust him, he has been an ase certified trans tech for over 10 15 years now) but maybe I'll find a decent set of rims at the junkyard or CL for cheep to throw some bigger snow/mud tires on.
so two weeks after I put the new clutch in and she's still runnin' like a top. fuel mileage is going up, having a clutch again instead of jammin' gears like a 16 year old in a 18 speed big rig is alot better on fuel.....whoda thunk it :yes:. can't wait for the holday season to be over so I can have money again so I can start buying material at work for the rocker channels and the light bar I want to make.
well I burried the darn thing in the snow last night, tried to turn at an intersection but the truck decided it wanted to go straight..... buried right to the axles, had to get a tow out, good thing I have roadside assistance :doh:
well, I decided last night that I need to invest in a new front bumper instead of a rear. I was taking some money to my roomate who was at the bar and the parking lot was pure ice. needless to say a decorative pole (an old tele pole cut into smaller sections) wanted to become friends with my bumper and in the process of the less than 5 mph bump, bent my bumper AND my new euro plate. :fs1:
just a bit, lol. when I get the bench seat I am going to have it recovered in the plaid cloth interior they used in the mkv (mark 5 ((gen 5))) golf gti.
I going to get a diy front bumper kit from JCR, I'm assuming the xj fronts are the same as the mj.
That's awesome... totally because I'm familiar with the material! You should make up a boser hood for it too! Don't forget to roll the fenders. :idea:
