Ok will it fit on the drag link end to? I mean its not going to be much but down south theres not much.of rock climbing mainly mudding but theres alot.of rocks to going into mud holes...does it also involve the tie rod tubing also? To upgrade?
The V8 ZJ tie rod will bolt up to your stock drag link. Or you can upgrade to a V8 ZJ drag link as it is stronger as well.
To do the tie rod upgrade you will need the following parts:
- Tie Rod
- Adjusting Sleeve
- Tie Rod End
These can all be purchased from autoparts stores.
I got the whole shebang, from the pitman arm to the steering knuckles off a V8 ZJ. The main thing is the tie rod being larger diameter AND a solid rod instead of our hollow tube being much stronger. Even if you put it into a rock, it will just bend a bit instead of buckling like the stock one will. Direct bolt-on.
Hey 87warrior
HOw much did it run you for that whOle set? Tie rod, adjusting sleeve ,and ends?
I honestly don't remember. Cost will depend on what brand you go with (i.e. Moog vs the parts store brand).
