hi my 88 manche has running lights and a left turn signal. i have no brake lights are a right turn signal.
i replaced the brake switch and all is the same.
i really need help fast I'm going to be driving it around noon tomarrow and would like to have every thang going
thanks Jon
o ya this is the back of the truck. everything in the front works
Check your fuses and fuse terminals on the panel. Sometimes a cleaning and tightening of the terminals can resolve gremlins. Also check your electrical connection below the left tail assembly.
:agree: "-Brake- lites" ,check these common failure areas :#1 worn sleeve bushings ( where switch attaches to pedal -shim or replace ) ,#2 ground ( behind L. tail-light -, sand,clean & tighten ) ,#3 bulbs and/or sockets :wrench:
Ok got it fixed. I checked everything like you guys said and it was the turn signal wiring. So I got that all replaced and works great now
Thanks for the help
