88whitemanche Posted September 26, 2012 Posted September 26, 2012 Hey guys If anyone has swapped the swapped the swaybar from a v8 sway bar how is the performance compared to the stock mj one and what harfware was needed to put the swaybar in or is it just like swap and go? Thanks
HOrnbrod Posted September 26, 2012 Posted September 26, 2012 It thicker than the MJ bar so you will need new bushings where it attaches to the cross brace. It mounts just like the stock bar. And it does help with body roll since it's beefier.
88whitemanche Posted September 26, 2012 Author Posted September 26, 2012 Nice ive only seen one down here hopefully no one has grabbed it
AMCJeepMJ Posted September 28, 2012 Posted September 28, 2012 Don't make the mistake of picking up a sway bar from an inline 6 equipped ZJ; the contour of the bar will not clear the bottom of an OEM-shaped radiator of a 2.5 equipped MJ.
88whitemanche Posted September 28, 2012 Author Posted September 28, 2012 Well the one I'm getting it from is the v8 zj
88whitemanche Posted September 30, 2012 Author Posted September 30, 2012 Well did the sway bar swap and it was all plug and go just keep the moynts from the zj and the handling is awesome huge difference!!!! Thabks hornbrod
HOrnbrod Posted September 30, 2012 Posted September 30, 2012 Well did the sway bar swap and it was all plug and go just keep the moynts from the zj and the handling is awesome huge difference!!!! Thabks hornbrod Welcome. Most of my front end is ZJ V8 components; sway bar, tie rod, steering box, and drag link. The steering stabilizer (OME) and track bar (Teraflex) are aftermarket. Works well for me. :thumbsup:
88whitemanche Posted September 30, 2012 Author Posted September 30, 2012 Cool...i was actually thinking about swapping over to moog products but for the cheap I migjt even take it into consideration
COFFMAN Posted October 1, 2012 Posted October 1, 2012 Welcome. Most of my front end is ZJ V8 components; sway bar, tie rod, steering box, and drag link. The steering stabilizer (OME) and track bar (Teraflex) are aftermarket. Works well for me. :thumbsup: Hornbrod what the crack with the ZJ steering box, bigger better brighter. tell us more. i might be needing one ??? :thumbsup:
HOrnbrod Posted October 1, 2012 Posted October 1, 2012 Quicker ratio, better drivability. http://comancheclub....ear#entry181307 http://www.chevelles.../ftecref29.html
88whitemanche Posted October 1, 2012 Author Posted October 1, 2012 Hey hornbrod how much more or less would everything be suspension wise from a v8 zj? Well just a rough number because the moog is suoer exspensive but also known for bang for your buck literally
HOrnbrod Posted October 1, 2012 Posted October 1, 2012 If you mean used stuff from a yard, no idea. Don't do that for steering or brakes. I used all NOS stuff I found on Ebay and other places. And Moog used to be good stuff. Now it's made in China like the rest of the junk unless you're lucky to find some original ols NOS stuff.
88whitemanche Posted October 1, 2012 Author Posted October 1, 2012 Well not used I mean brand new should I invest putting the v8 suspension...regarding track bar, tie rods, draglink and mainly in that area of suspension
HOrnbrod Posted October 1, 2012 Posted October 1, 2012 I kind of replaced my stuff as it wore out. And if your rig is over 100K it won't have far to go, especially if you run bigger tires. If I noticed slop somewhere, I replaced it. Usually you can find NOS Mopar stuff for the same or in some cases even less than offshore junk on Fleabay. Replaced the drag link last week; that was the last of the original front end, except for ball joints. They are next. here's a pretty good place for NOS Jeep parts. They have some great sales occasionally. http://www.tapcointernational.com/store/index.php/catalogsearch/result/?q=differential
