1988 Bronco
I know Explorer makes a good candidate for axle swap but how about a 1988 Bronco? I know nothing about them except that they're Fords. Also that they were based on the Ford F150. If it were closer I'd get it just for scrap but it's 90 miles away. It's 4WD. No engine. SEARCH was of no help.
the front axle on that model is called a TTB axle. I like to think of it as a scissor axle haha. It has a pivot point in the middle and is a Pain in the @$$ to work on, it is far from a bolt on for you.... I would say it is not worth time, and next to impossible to make the swap. you would need to make a radius arm set up and make a center axle mount under the engine. which to me would seem next to impossible with mj unibody....
