Blue88Comanche Posted August 6, 2012 Share Posted August 6, 2012 what is involved in replacing the dust / splash shield (or whatever it is called) on the MJ? I managed to bend up the ones on the donor axle and would like to replace them.. Thanks Link to comment Share on other sites More sharing options...
Geonovast Posted August 6, 2012 Share Posted August 6, 2012 You gotta pull the unit bearing. Dust shield goes between the bearing and knuckle. Just make sure it's lined up correctly when you put the new one on, or you'll be swearing twice as much when you pull the bearing off for a second time. Link to comment Share on other sites More sharing options...
mvusse Posted August 6, 2012 Share Posted August 6, 2012 I removed both of mine. Was tired of the screeching whenever I got a gravel pebble stuck between it and the rotor. No issues for almost 4 years now. Link to comment Share on other sites More sharing options...
mnkyboy Posted August 6, 2012 Share Posted August 6, 2012 I removed both of mine. Was tired of the screeching whenever I got a gravel pebble stuck between it and the rotor. No issues for almost 4 years now. Same here Link to comment Share on other sites More sharing options...
ParadiseMJ Posted August 7, 2012 Share Posted August 7, 2012 I have one intact and 1 missing. When I saw that I'd have remove the bearing to replace it I said no. Doesn't seem to make a difference either way. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted August 7, 2012 Author Share Posted August 7, 2012 so in theory i can just cut it off and not worry about it Link to comment Share on other sites More sharing options...
Pete M Posted August 7, 2012 Share Posted August 7, 2012 yup. :thumbsup: Link to comment Share on other sites More sharing options...
Blue88Comanche Posted August 7, 2012 Author Share Posted August 7, 2012 awesome, time to pull out the angle grinder :wrench: Link to comment Share on other sites More sharing options...
