For those that were woundering what it would look like if you put waggy rear leafs and a 8.8 under the rear of your MJ here it is what it could look like.
Could you make a measurement from the center of your hub to the top of your bedrails?
oh pretty please!
I want to go SOA with an 8.8 but I'm worried about being high in the rear.
The front is a so called 3.5" spring of unknown brand and a 1.75" spacer, so I am guessing its around 5" or so. The only measurement I recall is its 29" to bottom of my bumper, but I will get that other measurement for you guys. The waggy spring are a little stiffer than the stock springs but thats ok for me as it rides more like a truck now.
did the waggy springs bolt right in, or did you have to make new mounts for them?
They are a direct bolt up, but I did slip a couple washers in the front eye bucket to tighten it up a little. As for the distance between the hub and the top rail its about 37".
.....I thought that I read on here somewheres that the leaf springs would not interchange, different lengths?
Different arch. Some people on here knew they were the correct eye to center pin measurements, but realized that they didn't have enough arch to be a direct replacement.
You've got me curious on using MJ springs on a FSJ now...
minydigger says they bolted right in with the exception of a few spacers to tighten them up. i thought that myself, but if he got it done then i believe him.
But that measurement is from the ground to the bottom edge of my flair, IIRC.
I can measure rom mid hub to the top of my bed later today...
CW
CW
Oh! Okay, yes please do!
Yeah sorry, should of been more clear on what they came off of. The ones I got where off of a 86' wagoneer (full size) They are flatter than the stock springs as I used them to lower the rear of my truck after I SOAed it with an 8.8. They are the same length as stock MJ springs 57"
