89JeepMJ Posted July 18, 2012 Posted July 18, 2012 has anyone ever done this but not mudded it up and blocked it to make it all blend in. I'm looking for a repair where you turned it into something cooler. I'm thinking like a black panel with silver rivets or bolts with chrome heads. pictures would be great thanks
sinkrun Posted July 19, 2012 Posted July 19, 2012 No pictures but somewhere I have seen Diamond plate with black bolts or rivets neatly done. I have been thinking of this myself lately as mine is where it has to have something done soon. I did just weld rockers on and floors (first time) and used black chip guard to hide my novice work. Its going to be hard to hide novice work on the bed.
89JeepMJ Posted July 19, 2012 Author Posted July 19, 2012 i looked for a picture of what i was thinking but couldnt find one
sinkrun Posted July 19, 2012 Posted July 19, 2012 I think it was a members truck maybe Wades or super wade hes not on here much anymore it was a blue truck(maybe). Anyone?
ComancheKid45 Posted July 19, 2012 Posted July 19, 2012 I'm pretty sure your talking about "CW Long Shot" Image Not Found His whole build thread can be seen here http://comancheclub.com/forums/viewtopic.php?t=1230
Automan2164 Posted July 19, 2012 Posted July 19, 2012 CW just basically moved his flares up into the stratosphere to rid the rust, but the diamond plate helped a bit.
89JeepMJ Posted July 19, 2012 Author Posted July 19, 2012 http://www.dakota-durango.com/forum/sho ... p?t=155248 Kinda like this but down closer to the body ling on a MJ and it would be behind the flare. also be a lot more nicely done
89JeepMJ Posted November 22, 2012 Author Posted November 22, 2012 I finally did want i had in mind check it out maybe it'll give you guys some ideas:
89JeepMJ Posted November 22, 2012 Author Posted November 22, 2012 got rid of the rust but still added a cool look at the same time, i think.
ftpiercecracker1 Posted November 22, 2012 Posted November 22, 2012 Dude that looks freakin awesome :eek: Even if i didnt have rust, which i do, i would put those on. What exactly did you use? obviously rivets, but what gauge steel and i guess a plasma torch?
89JeepMJ Posted November 22, 2012 Author Posted November 22, 2012 aluminum rivets, 14 guage aluminum sheet, gloss black and black silicone. i used a scroll saw to cut it out cause aluminum is so soft. made foam board templates which all the drawing up and figuring out the angles and all, that took the longest time.
Automan2164 Posted November 23, 2012 Posted November 23, 2012 Doesn't look half bad for sprucing up a work truck. Rob
Carl'sMJ Posted November 23, 2012 Posted November 23, 2012 Looks good... Did you cut out all the rust behind it or just cover it up?
ftpiercecracker1 Posted November 23, 2012 Posted November 23, 2012 Do i want to know how much that aluminum cost?
89JeepMJ Posted November 23, 2012 Author Posted November 23, 2012 Yes i did cut out the rust and spruced it all up before hand. Price for the aluminum, i couldnt tell ya because i work at a collision shop for commerical truck so needless to say the scrap pile holds wonders.
ftpiercecracker1 Posted November 23, 2012 Posted November 23, 2012 Price for the aluminum, i couldnt tell ya because i work at a collision shop for commerical truck so needless to say the scrap pile holds wonders. You lucky bass turd :fs1:
