rnobles Posted July 3, 2012 Share Posted July 3, 2012 I have pretty much decided to just keep my 2.5 and just rebuild the motor. I'm also ready to do the 4wd conversion. My local jy has a 86 2.5 4wd cherokee with complete driveline intact....it has 4speed manual (ax4 i assume) np207?? and 4.11 gears. i was quoted $825 for everything, front and rear axles, front driveshaft, tranny and transfercase, flywheel, clutch pedal assembly etc...everything but the motor. Anything i should be considering given this driveline? Is that price reasonable for what I'm getting? My rig will not be used for anything close to hardcore, maybe a little playing here and there but mostly a DD type of truck that is capable of going offroad and getting back home. Link to comment Share on other sites More sharing options...
Pete M Posted July 3, 2012 Share Posted July 3, 2012 in theory you should be able to buy a whole XJ for less than that. Either way I would keep looking for a later model with the 231 and AX-5. :thumbsup: (2.5L + AX-4 usually equals 3.55 gears so triple check before buying) and speaking of ratios, what ratio is that in your rear axle now? Link to comment Share on other sites More sharing options...
jimoshel Posted July 3, 2012 Share Posted July 3, 2012 I just got a '94 XJ with 2.5, AX15, 4WD for $450. Runs good. Complete. Come get it, you can have it for $500. Don't buy parts from a JY. Get a complete donor and sell what you don't use. Link to comment Share on other sites More sharing options...
Dadinator Posted July 3, 2012 Share Posted July 3, 2012 :agree: I got a whole totaled XJ with a 4.0 and ax15 for $400 last year that I used for my mule. See my build in my sig to see what i got. Pulled a million parts off of it. I actually sold what was left this year a little soon. I wish I would've pulled a couple more parts off of it. Oh well. $825 is too much for what you're getting. Shop around. Check Craigslist and stuff. If you aren't desparate for parts for a driver and are getting it for a project, definitely keep shopping. Link to comment Share on other sites More sharing options...
rnobles Posted July 3, 2012 Author Share Posted July 3, 2012 Quote in theory you should be able to buy a whole XJ for less than that. Either way I would keep looking for a later model with the 231 and AX-5. :thumbsup: (2.5L + AX-4 usually equals 3.55 gears so triple check before buying) and speaking of ratios, what ratio is that in your rear axle now? I agree, in theory i should be able to find one in that price range, but around here i have not had any luck. i currently have 3.55s with the A904 3spd auto tranny.....its sad. lol i would prefer a 4.0 doner rig but have accepted that my 86 causes a few headaches with that swap and will be fine with the 2.5, just for simplicity. At this point i will take what i can get. the going rate around here seems to be in the 1000-2000 range for anything that runs....IF you can find one. Link to comment Share on other sites More sharing options...
Zenobian_84 Posted July 3, 2012 Share Posted July 3, 2012 rnobles said: Quote in theory you should be able to buy a whole XJ for less than that. Either way I would keep looking for a later model with the 231 and AX-5. :thumbsup: (2.5L + AX-4 usually equals 3.55 gears so triple check before buying) and speaking of ratios, what ratio is that in your rear axle now? I agree, in theory i should be able to find one in that price range, but around here i have not had any luck. i currently have 3.55s with the A904 3spd auto tranny.....its sad. lol i would prefer a 4.0 doner rig but have accepted that my 86 causes a few headaches with that swap and will be fine with the 2.5, just for simplicity. At this point i will take what i can get. the going rate around here seems to be in the 1000-2000 range for anything that runs....IF you can find one. I feel your pain. There is no such thing as a "Cheap Jeep" down here. Even for the most clapped out pieces of crap, people still want upwards of $900 and absolutely refuse to budge any lower. Either that, or they charge arms and legs when they part them out. :fs1: I'm all for staying on the look until I find a deal, but when it gets down to it, sometimes you have to bite the bullet and throw down some $. Link to comment Share on other sites More sharing options...
mvusse Posted July 4, 2012 Share Posted July 4, 2012 jimoshel said: I just got a '94 XJ with 2.5, AX15, 4WD for $450. Runs good. Complete. Come get it, you can have it for $500. Don't buy parts from a JY. Get a complete donor and sell what you don't use. AX5? Link to comment Share on other sites More sharing options...
jimoshel Posted July 4, 2012 Share Posted July 4, 2012 OOOPS!! :oops: Link to comment Share on other sites More sharing options...
