87Warrior Posted June 15, 2012 Share Posted June 15, 2012 Well, can you surface a 2.5L flywheel? I was reading through the 2.5L section of the FSM again and noticed it mentioned checking the flywheel with a straight edge. If not, what is the best way to clean it up? Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted June 15, 2012 Share Posted June 15, 2012 When I did my clutch last year, I took my flywheel down to the local Napa machine shop for just that. Link to comment Share on other sites More sharing options...
xjrev10 Posted June 20, 2012 Share Posted June 20, 2012 Yes. On a 4.0 you cannot. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 20, 2012 Share Posted June 20, 2012 IIRC, we turned the flywheels on 4.0s at least up through 1992 when I left. I have heard that you can't do it on the LATE 4.0s. Link to comment Share on other sites More sharing options...
87Warrior Posted June 20, 2012 Author Share Posted June 20, 2012 $30 later my 2.5 fltwheel looks new again. Now to press in that pilot bearing. Thanks for the info guys. :jump: Link to comment Share on other sites More sharing options...
Eagle Posted June 21, 2012 Share Posted June 21, 2012 IIRC, we turned the flywheels on 4.0s at least up through 1992 when I left. I have heard that you can't do it on the LATE 4.0s. The FSM for my '88 4.0L Cherokee specifically says not to turn the flywheel. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 21, 2012 Share Posted June 21, 2012 IIRC, we turned the flywheels on 4.0s at least up through 1992 when I left. I have heard that you can't do it on the LATE 4.0s. The FSM for my '88 4.0L Cherokee specifically says not to turn the flywheel. Really? Does it say why? We sure turned a bunch of them. Link to comment Share on other sites More sharing options...
xjrev10 Posted June 21, 2012 Share Posted June 21, 2012 IIRC, we turned the flywheels on 4.0s at least up through 1992 when I left. I have heard that you can't do it on the LATE 4.0s. The FSM for my '88 4.0L Cherokee specifically says not to turn the flywheel. Really? Does it say why? We sure turned a bunch of them. IIRC I remember reading that they had a slight bevel to them. If they where machined flat, obviously the bevel is no more. Sounds like it will 'work' just eat the clutch disk up faster and will not operate like it should. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 21, 2012 Share Posted June 21, 2012 I thought on the later ones that the throwout bearing/slave didn't have enough throw in them to push the clutch if material had been removed from the flywheel. Link to comment Share on other sites More sharing options...
Eagle Posted June 21, 2012 Share Posted June 21, 2012 The FSM for my '88 4.0L Cherokee specifically says not to turn the flywheel. Really? Does it say why? We sure turned a bunch of them. It says something about a special contour, but it doesn't say what that contour is. The consensus is that it's slightly dished. I only know of a few people from NAXJA who have had the flywheel turned, and they all had problems. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 21, 2012 Share Posted June 21, 2012 I guess we dodged a few bullets then.... Link to comment Share on other sites More sharing options...
