MJRemi Posted June 2, 2012 Share Posted June 2, 2012 I'd like to remove the exterior side panels from the bed of the '86 but have never done any type of body work before. I have cutting wheels and a sawzall but I do not want to hack the panel up. I want clean cuts or prefer to keep the entire panel as intact as possible. Any words of wisdom from experienced members are welcome. FYI: I will be using the lower section between the front of the bed (driver side) and the wheel well to patch damage on the Street Comanche. I have a buyer for both top rails from front to back and 8" in height. The rest is left-overs. Image Not Found Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 2, 2012 Share Posted June 2, 2012 I've never done it but I've seen it done. Spot welds are drilled out and the panel peals off. Nothing should get cut at all unless you are cutting the patch. Link to comment Share on other sites More sharing options...
sinkrun Posted June 2, 2012 Share Posted June 2, 2012 Yes spot welds drilled and then the panels is pealed off I am no pro but have been teaching myself the last year. You tube and searching google can find some videos not on a Comanche but same idea. I am about a week from cutting out a section from above the wheel well (if I can find a patch) there will be some spot welds if I can get to it i will take some pictures also taking off the rockers lots of spot welds there to. Link to comment Share on other sites More sharing options...
MJRemi Posted June 2, 2012 Author Share Posted June 2, 2012 10-4 on the spot-welds. I'll do the removal in July and if the left-overs can cover your needed patches, sinkrun, I'll be glad to cut and send the patch metal to you for shipping cost only. Link to comment Share on other sites More sharing options...
Automan2164 Posted June 2, 2012 Share Posted June 2, 2012 They make spot weld drill bits that work fantastic. I would highly recommend one. The pin keeps it centered, and it cuts around the spot weld rather than through it. Rob Link to comment Share on other sites More sharing options...
sinkrun Posted June 2, 2012 Share Posted June 2, 2012 I buy my cutters from this guy on ebay very good stuff and cheap compared to retail welding shops. http://www.ebay.com/itm/380329558913?ss ... 1438.l2649 Link to comment Share on other sites More sharing options...
JENSSEN Posted June 2, 2012 Share Posted June 2, 2012 I just did a box side on my 90 it's on my build pm me if you need extra pics or videos Link to comment Share on other sites More sharing options...
