Hey guys, The water pump pully on "Oscar" has the case of the wobbles. It also makes a pretty loud noise. The water pump itself is not leaking and the trucks cooling system operates flawlessly. Is there a bearing for the pulley itself that can be swapped or is a replacement of the whole pump in order?
Thanks! ;)
Whole pump needs replaced there not very much less than $40 new at autozone! The bearings seem to be pressed into the cast housing so I don't see the bearings just beeing replaced especially for a new pump with a lifetime warranty for $40.
yup. easy enough to do. did my last one on the side of the freeway. :D (at a rest stop technically)
Me too, Pete. :D
