E4Marty Posted May 4, 2012 Share Posted May 4, 2012 Aside from the fact that the pump at the gas statio didnt click off, with a full tank the gauge reads nearly horizontal past full. Is this a bad fuel pump, or someone pulling off the needle(the gauge cluster cover is removed. Link to comment Share on other sites More sharing options...
Zenobian_84 Posted May 5, 2012 Share Posted May 5, 2012 Probably means your gas guage itself is fubar. Mine did the same thing. Try swapping in another, known, GOOD gauge to test it. If the working gauge goes to full (I believe, not 100% sure) then your fuel sending unit is toast. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 5, 2012 Share Posted May 5, 2012 Clean your grounds. Link to comment Share on other sites More sharing options...
E4Marty Posted May 8, 2012 Author Share Posted May 8, 2012 is the ground right on or near the tank? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 8, 2012 Share Posted May 8, 2012 is the ground right on or near the tank? It's behind the left side tail lamp. Link to comment Share on other sites More sharing options...
E4Marty Posted May 23, 2012 Author Share Posted May 23, 2012 I think that may have fixed it. The ground behind the tail-light wasn't hooked up at all. I put a new connection on and screwed it to the bed with the taillight screws. Found out the hard way, the pump at the gas station doesn't click off on full, so we'll see if it's accurate another time. Link to comment Share on other sites More sharing options...
