bbe Posted April 24, 2012 Share Posted April 24, 2012 I live on the coast in FL, I'm in TN at about 2000 elevation In Coker Creek, my MJ has no power going uphill, like 15-25 mph with the pedel to the metal. I have a 400 mile trip home at the end of the week and really need some help. I am in SE TN near Telico Plains, What is wrong with my truck? I pulled a trailer from FL here with no problems It started the next day. I'm on a borrowed computer and will check back asap any suggestions I am no mechanic thanks, Bill Link to comment Share on other sites More sharing options...
Geonovast Posted April 24, 2012 Share Posted April 24, 2012 Does it run fine on level ground? I had issues like that when my fuel pump was on its way out. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 24, 2012 Share Posted April 24, 2012 If you still have the original catalytic converter on it, it's probably clogged. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 24, 2012 Share Posted April 24, 2012 Ex FL boy here and I'm just down the road from ya now, other side of Knoxville. I have no idea what your problem his however it ain't the elevation so you can rule that out. I've had mine all over the SE and elevation has play no role in the way it runs. 40ft or 4000ft makes no difference. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 24, 2012 Share Posted April 24, 2012 Fuel filter, fuel pump, or oil saturated air filter would be at the top of my guess list. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted April 25, 2012 Share Posted April 25, 2012 Manual tranny?? Is your clutch slipping? Automatic?? Is your fluid nice n' red and at correct level?? Does your CAT rattle? Link to comment Share on other sites More sharing options...
MJ1337 Posted April 26, 2012 Share Posted April 26, 2012 o2 sensor Link to comment Share on other sites More sharing options...
carnuck Posted June 7, 2012 Share Posted June 7, 2012 Bit late, but run a can of injector cleaner through. Loosen up the joint between the cat and front pipe, put nuts between the 2 pipes for a spacer to see if the power comes back. Pull to the shoulder, shut it off, wait 15 minutes then try again. Renix resets everything on each restart, so it will adjust for altitude. (found that out going to Ouray) Link to comment Share on other sites More sharing options...
