when i turn my lights on my left blinker lights up on the dash not on the outside. I have changed headlight harness & dash harness. what else would cause this?
Thanks in advance
That's funny, mine did the same thing until I had to take it out to replace the speedo cable.
So I say take it out..........fiddle with it a minute......put it back in.........lol
there's a short somewhere in your wiring for either the external turn signal light or the indicator light in the dash, so the indicator think's the light is on b/c power is being drained somewhere
Look at the lights at night. I had the same issue and noticed when my headlights were flicked on the left indicator turned on at slight power too. Replaced the blinker socket and the problem was solved.
Do you mean replace the whole socket assembly, or just the bulb? Same problem as jasongreg, to a T, and I've been trying to figure out the solution for about a week. :fs1:
Pull the bulb and take a look. I replaced the whole socket as it costed $5/6 and took maybe 15 minutes to pull the old one and solder in the new. But my socket was visually corroded pretty badly.
