High2by Posted April 4, 2012 Share Posted April 4, 2012 I am in the process of trying to fix up my MJ and get it to looking respectable. I bought the Autopal housings and bulbs and also a new HD wiring harness and a set of clear corners and turn signal lenses. I know mine is just a 2wd, but it's still a Comanche. :D I painted the grill and headlight surrounds and put all that in a newish header panel. Before: Image Not Found After: Image Not Found I still have alot of work to do but it's a work in progress. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 4, 2012 Share Posted April 4, 2012 You will like the headlights and harness as long as you use the e-code Autopals. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted April 4, 2012 Share Posted April 4, 2012 the clear corners look killer. :chillin: some window tint and a paint job would really helps things out too Link to comment Share on other sites More sharing options...
JENSSEN Posted April 4, 2012 Share Posted April 4, 2012 I used Hella lamps and some HID kits from www.chandaauto.ca Love them in the TJ and XJ,.. :) Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 4, 2012 Share Posted April 4, 2012 You will like the headlights and harness as long as you use the e-code Autopals. You will like the E-code Autopals because just about anything is an upgrade over the OEM sealed beams. But if you see the difference between the Autopals and the E-code Hellas, you won't like the Autopals much anymore. Link to comment Share on other sites More sharing options...
High2by Posted April 4, 2012 Author Share Posted April 4, 2012 I got the E-code housings and the standard 55/60 watt bulbs but it's a night and day difference compared to stock. I could've gotten bigger bulbs but I figured I'd run these and then when time comes, I could get a larger one if I felt I needed too. I love the HID's but this being my DD, I didn't want to take a chance of not being able to adjust them so they wouldn't blind traffic, but for an off road rig, absolutely!! I want to put a solid rear window in it and get rid of the slider and when I do that, the windows go dark. :D Then, hopefully by the end of summer, it's gonna get some paint. Thanks guys. :cheers: Link to comment Share on other sites More sharing options...
cruiser54 Posted April 4, 2012 Share Posted April 4, 2012 Have you installed the harness yet? Link to comment Share on other sites More sharing options...
High2by Posted April 4, 2012 Author Share Posted April 4, 2012 Yea. It was easy as pie to install. Only issue I had with it was it was in a bright yellow plastic loom. You know how hard it is to hide a yellow harness behind a black grill so you can't see it???? :doh: I guess I could've painted it but I didn't feel like it. It's in there and it's hid pretty good so I am happy with it. I mounted the relays on the fender well behind the battery. I'll try and get a picture of the relays. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 4, 2012 Share Posted April 4, 2012 I put split-loom over mine. I hate yellow!!! Link to comment Share on other sites More sharing options...
