jakeWI Posted March 20, 2012 Share Posted March 20, 2012 Year, Make, Model. 1991, Jeep Comanche Eliminator Image, if available Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0L/2wd AW4/NA/2wd/D35 Build date: (its on the driverside door sticker, in the form of month and year) Current Location: Region will do, state, and area of state. Midwest, SE WI Status: Is it still on the road, is it in the junkyard? Project awaiting work? Still on the road about to get a paint job and 4wd conversion Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. PINK!, grey interior with buckets and floor shift. All original stock Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. ME Link to comment Share on other sites More sharing options...
lostissues Posted March 20, 2012 Share Posted March 20, 2012 yep, that sure is a pink Comanche. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 25, 2015 Share Posted April 25, 2015 Do you have the VIN? Link to comment Share on other sites More sharing options...
JMO413 Posted May 25, 2019 Share Posted May 25, 2019 no vin Link to comment Share on other sites More sharing options...
jdog Posted February 1, 2021 Share Posted February 1, 2021 kinda wish this had a vin On 3/19/2012 at 7:37 PM, jakeWI said: Year, Make, Model. 1991, Jeep Comanche Eliminator Image, if available /uploads/archive/41e132fc6bdd170172b4c24efd5befe3/89e84b5997fc2c453e573444e31d3b0b.jpg Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0L/2wd AW4/NA/2wd/D35 Build date: (its on the driverside door sticker, in the form of month and year) Current Location: Region will do, state, and area of state. Midwest, SE WI Status: Is it still on the road, is it in the junkyard? Project awaiting work? Still on the road about to get a paint job and 4wd conversion Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. PINK!, grey interior with buckets and floor shift. All original stock Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. ME Link to comment Share on other sites More sharing options...
