no vibs for me either at 4.5. something else was wrong there.
you'll need that longer track bar. and longer brake lines. and longer sway bar links.
whats a sway bar? :D
it's that thing that helps keep you alive should you need to avoid something in the road. :D
An SYE is a great upgrade. but it is kinda expensive and requires a new driveshaft too. Either way, lifting an MJ up that high will pull the stock driveshaft out about an inch and that can cause issues.
Will I need a pitman arm>?
I'm trying to go minimal on this.
Like I don't NEED a SYE, but i could use one.
depends on what track bar you go with. the stock piman arm should be retained unless you go with a trackbar with a drop bracket. the track bar and drag link need to be as close to parallel as possible.
(also, the pitman arm from a TJ will give a small drop :thumbsup: )
i don't see why you wouldnt get a track bar with the bracket. now days its kind of $#!&ty if it doesnt come with one IMO
make sure to get one with a heim
i guess I'm for the "get the hell out of my way or your run over" policy 8) :shake:
i don't see why you wouldnt get a track bar with the bracket. now days its kind of $#!& if it doesnt come with one IMO
not just A bracket, but a drop bracket. they come both ways. :thumbsup:
i would stay away from the cheapo shocks, had procom es9000 on mine then threw on some bilesteine 5125's and noticed quite a nice difference.
pro comps suck......
