1987 Radio Wiring
I looked in the search... I found 1988-1990.. not 1987. I was just wondering if anyone had any info? I got a cassette radio from a 1995-1996 (maybe, had a airbag) cherokee and it had the plug most do but mine in my truck does not, just a bunch of wires...
Any help will be appreciated.
Don't know if this will help, but this is what I figured out from when I was attempting to install a 94 XJ into my 87 (ended up going aftermarket because the tape deck was shot.)
1994 XJ Radio Wiring ------------ 1987 MJ Radio Wiring
Constant 12V - Pink ||| Constant 12V - Red/Gray
Switched 12V -Purple/White ||| Switched 12V - Purple/Orange
Ground - Black ||| Ground - Black
*Illumination - Light Blue/Red ||| Illumination - Blue?
*Dimmer - Orange ||| Dimmer - Orange/Black?
*Antenna Trigger - Purple/Orange ||| Antenna Trigger - N/A?
--Front Speakers--
Left Front (+) - Dark Green ||| Left Front (+) - Green
Left Front (-) - Brown/Red ||| Left Front (-) - Black/White
Right Front (+) - Purple ||| Right Front (+) - White
Right Front (-) - Dark Blue/Red ||| Right Front (-) - Black
--Rear Speakers-- (Not Important Since I don't have any) -----
Left Rear (+) - Brown/Yellow
Left Rear (-) - Brown/Light Blue
Right Rear (+) - Dark Blue/White
Right Rear (-) - Dark Blue/Orange
* --> Not sure if these are correctly connected (as I couldn't see any illumination in the unit when I was working on it.)
Hope this helps man.
I looked good behind there today and saw the writing on some of the wires.. Then I saw like the LF and LR were connected with 1 wire.. Is that good or bad? Because the passsenger side of my truck, the speakers stopped working..
I got them plugged together but no sound out of the speakers. I turn the power on to the radio and I hear a click then I go to fm and go to a station and silence. I did try to solder the whole headphone aux cord thing. Would that have done anything maybe make the radio come on but no sound?
Maybe have burnt something?
Thanks
