I'm planning on doing my lift at the end of the month. Just trying to get my ducks in a row before i start. I was able to find a set of RE's for the front but was looking for some info for the rear. Part # for some bilstein's would be awesome.
Thanks in advance
Tom
I'm trying to figure out the same thing, Tom. It depends on where you have your lower shock mounts. I have mine welded on the axle tube right on the centerline. My static eye-to-eye distance is 19 inches.
I guess you're supposed to have more downtravel than uptravel. Bilstein has a 10-inch travel 5100 shock that has a compressed length of about 15 inches and an extended length of about 25 inches.
I'm thinking that this would work in my case. I just have to borrow a friend's forklift to confirm that I have the proper bump stopping.
When I set rigs up at the shop we use a forklift to cycle the suspension,then we know exactly what we need for shock length.
I would find someone with a forklift or an RTI ramp,without cycling the suspension your basically guessing.
fwiw when i relocated mine to the tube (slightly lower than center, front), - that turned-out to be the exact same distance as the original distance, so i just used my stock shocks. this is my first experience with this but i don't see anything wrong with this method, plus it will make ordering new ones very easy.
Thats where mine is going to be also. :cheers:
i have 12" travel 5100s with the shock mount just below the bottom of the tube.
