Over the course of the day, driving to and from school, I have noticed a hiss in the accleration of my truck (89'). The best way I can describe this sound is that it is similar to air escaping out of a pressurized bottle with a little "squeak" to it. The sound only occurs in the 2000-2600 rpm range. The two most recent activities that have occured on the truck was the replacement of the muffler and catalytic converter last Saturday, and yesterday afternoon I took the throttle body off to clean it and the IAC. Now I know the first thing that might come to mind would be vaccum leak right? Well the funny thing is the idle is fine. It idles between 800-1000 rpm in park with no roughness being transferred to the body, and 700-900 in drive under brake. Also the sound only occurs in drive under accleration or if I hold the pedal steady to keep the rpms in between 2000-2600. As far as I can tell it does not harm the truck in any discernable way (and hopefully never will :roll: ) Any help that could be given at this point would be very welcome.
Thanks y'all
what about a small leak somewhere between the TB and air filter? that could make noise but not really affect idle. maybe. :dunno:
Your description sounds like when mine had an exhaust leak. You could have messed with something when you replaced the muffler... On mine the intake/exhaust gasket tore and pushed out near the front of the motor. It made a weird hissing/squeaking noise. Cracked headers are also common. :wrench:
Ironically the header was repaired once already for cracks as you say. Also I did not previously mention but, the muffler is also loudest at the exact same rpm that the sound happens at. Tomorrow I plan on running the truck and spraying some carbuerator cleaner around the TB to check for leaks. If it doesnt change the idle then I think it might be safe to assume it is either a leak in the muffler or in one of the welds. A muffler shop down here mounted it because I don't have a welder so they should be able to fix it at no cost...(hopefully) :roll:
As for the intake gasket it may have been aggravated when I pilled the TB off so if all else fails may have to replace it
Well I just tried the carberatour cleaner and I came up zip for vaccum leaks. The truck is snugged up tight. I tried listening more with the hood open and it sounds like it is coming from somewhere around the fan belt but if it was a pully it would happen all the time right? I talked it over with my father (Akula69), and the best we could come up with was thermostatic clutch..maybe? :dunno:
Do you have a cold air intake or a stock air box? I have a cheap air intake with cone filter and it hisses and wistles at higher RPMS
Also get a mecanics thethascope and listen at each pully with it.
New gasket installed under the TB after it was removed?
Yeah my 89 MJ had the same noise and i replaced the TB gasket and it fixed the prob :wrench:
The airbox is the stock one that came with the truck.
The airbox is the stock one that came with the truck. Where can I get one of those?
Did the faulty gasket affect the idle at all?
Ebay or you can make one pretty easy. I made one once out of exuahst tubing and a 5/8 straight fitting. little paint ahe it looked really good.
I don't think it effected the idle, it started make the sound and I realized it was the coming from the TB and I removed it and saw the was bad so I changed it.
Do you cut your own gaskets or buy them new?
I buy new ones, I got a felpro gasket for it
Oh I see..we cut ours from gasket maker material so if I cut it wrong or punched the holes incorrectly that may be the problem
