HOrnbrod Posted January 24, 2012 Posted January 24, 2012 I have a 1988 D44 rear axle installed. Is the vent fitting for this axle that the vacuum tube connects to threaded into the left axle tube hole or is it a press fit? I see two types on Team Cherokee's site. :hmm:
Motion Offroad Posted January 24, 2012 Posted January 24, 2012 All the XJ/MJ D44 axle's I've came across had the pressed-in barb.
HOrnbrod Posted January 24, 2012 Author Posted January 24, 2012 Hmmm. I cross the p/n from the 86-89 manual (J3187999) for the D44 and get this: The one that's in there now is plastic, pressed in. Don't know if it's original or not. Checked again. The metal threaded one is the old design. It was superseded by this plastic one: I think I'll get the metal one. Gotta seal a lot better than the plastic POS. :D
86FUBAR Posted January 24, 2012 Posted January 24, 2012 Definitely use the metal one , when I installed the d44 in my manch I swiped the breather bolt off of a 80s ford as it is a hollow bolt that also holds down the brake line , it's a much cleaner way to go I think . It isn't a direct bolt on but dosnt take much to make work.
jeepcoma Posted January 24, 2012 Posted January 24, 2012 I had the same problem when I swapped my stock '91 D35 for an '88 D44, the breather was different (though thread vs press seems inconsistent; maybe it's related to MT vs AT?). I had to secure the brake splitter with zip ties as a temporary solution. I ended up tapping the breather hole on my D44 to fit the threaded breather/brake bolt. Seemed like the right decision, just hope I got all the metal shavings from tapping out.
HOrnbrod Posted January 24, 2012 Author Posted January 24, 2012 I had the same problem when I swapped my stock '91 D35 for an '88 D44, the breather was different (though thread vs press seems inconsistent; maybe it's related to MT vs AT?). I had to secure the brake splitter with zip ties as a temporary solution. I ended up tapping the breather hole on my D44 to fit the threaded breather/brake bolt. Seemed like the right decision, just hope I got all the metal shavings from tapping out. Thanks jeepcoma. Do you happen to remember what tap size you used? I'm guessing 1/8 NPT? :cheers:
jeepcoma Posted January 24, 2012 Posted January 24, 2012 Thanks jeepcoma. Do you happen to remember what tap size you used? I'm guessing 1/8 NPT? :cheers: I don't recall, but I'll check my taps when I get home. I used a new kit so it'll be the only one with grease on it so I should be able to tell. During the process, I stuffed the hole with grease and cut very slowly, backing the tap out often to clean shards off and re-greasing. When finished, scoop all the grease out and hopefully any filings left come out with it. Keep greasing and cleaning it out until it's clean.
mjeff87 Posted January 24, 2012 Posted January 24, 2012 If that's the same threaded vent from an 8.25, the bit size is 25/64" and the tap is 7/16x20 (swapped one of them bad Larry's onto the D44 I am running :D ) I shortened the end of it up a bit with a grinder to prevent contact with the axleshaft: Image Not Found View from inside the tube: Image Not Found Installed: Image Not Found
HOrnbrod Posted January 24, 2012 Author Posted January 24, 2012 Thanks Jeff, that helps a lot. The vent fitting on mine is the plastic piece with a nipple pressed into the circled hole. Is that a pipe plug in the hole on your axle? When I get the parts I'll do what you did.
mjeff87 Posted January 24, 2012 Posted January 24, 2012 it's a threaded bolt, there's a little metal bracket that holds the brakeline on that side that is (was) held on by 2 of them.
HOrnbrod Posted January 24, 2012 Author Posted January 24, 2012 Got it. ASSuME the threaded hole goes all the way through the axle tube, so it can also be used as a vent w. the correct adapter?
