Paul Bruchal Posted January 18, 2012 Share Posted January 18, 2012 Could somebody take a pic of there rear axle with the break lines/hoses showing, please? A pic with SOA set up would be best. I just want to see what its suppose to look like. Mine is covered in rust and a hose is almost cut in half from rubbing on a metal piece. Link to comment Share on other sites More sharing options...
mjeff87 Posted January 18, 2012 Share Posted January 18, 2012 these help any? Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
89eliminator Posted January 18, 2012 Share Posted January 18, 2012 here is what i did Link to comment Share on other sites More sharing options...
Paul Bruchal Posted January 19, 2012 Author Share Posted January 19, 2012 Thanks for posting. So when I order longer steel break lines, do I need 3 or 4 lines? I heard that XJs have 3. IDK if its the same for the MJ. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 19, 2012 Share Posted January 19, 2012 should be 3 unless something was changed, 2 front 1 rear Link to comment Share on other sites More sharing options...
Paul Bruchal Posted January 19, 2012 Author Share Posted January 19, 2012 Okay, What are these 2 lines? The one on my driver side is cut in half almost. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 19, 2012 Share Posted January 19, 2012 Okay, What are these 2 lines? The one on my driver side is cut in half almost. parking break cables Link to comment Share on other sites More sharing options...
ShadeMJ Posted January 19, 2012 Share Posted January 19, 2012 a little late but a simple diagram. also as BlueComanche88 said those are the parking break cables Link to comment Share on other sites More sharing options...
Paul Bruchal Posted January 19, 2012 Author Share Posted January 19, 2012 That enplanes the parking brake not working.. Thanks for the help and diagram! Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 19, 2012 Share Posted January 19, 2012 a little late but a simple diagram. also as Blue88Comanche said those are the parking break cables you just have 3 soft lines 2 front and one in the rear that t's off to 2 hard lines on the axle... brake cyl./ front distro block/ 2 front lines/2 rear hard lines/ one hardline is the primary rear brake line that goes to the height sensor then to the axle block, the other hardline is a bypass line (if the front brakes fail the bypass line kicks in and puts full power to the rear). the diagram is one option if you wanted to remove the height sensor, and it does not show the rear prop valve Link to comment Share on other sites More sharing options...
ShadeMJ Posted January 19, 2012 Share Posted January 19, 2012 you just have 3 soft lines 2 front and one in the rear that t's off to 2 hard lines on the axle... brake cyl./ front distro block/ 2 front lines/2 rear hard lines/ one hardline is the primary rear brake line that goes to the height sensor then to the axle block, the other hardline is a bypass line (if the front brakes fail the bypass line kicks in and puts full power to the rear). the diagram is one option if you wanted to remove the height sensor, and it does not show the rear prop valve It was meant more to show how the 3 soft lines ran as that's what he will need to replace but yes you are correct also I didn't make the diagram someone posted it in the mj info pic thread. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 19, 2012 Share Posted January 19, 2012 you just have 3 soft lines 2 front and one in the rear that t's off to 2 hard lines on the axle... brake cyl./ front distro block/ 2 front lines/2 rear hard lines/ one hardline is the primary rear brake line that goes to the height sensor then to the axle block, the other hardline is a bypass line (if the front brakes fail the bypass line kicks in and puts full power to the rear). the diagram is one option if you wanted to remove the height sensor, and it does not show the rear prop valve It was meant more to show how the 3 soft lines ran as that's what he will need to replace but yes you are correct also I didn't make the diagram someone posted it in the mj info pic thread. no prob :thumbsup: just adding detail to the diagram :cheers: Link to comment Share on other sites More sharing options...
89eliminator Posted January 19, 2012 Share Posted January 19, 2012 Okay, What are these 2 lines? The one on my driver side is cut in half almost. parking brake cables, that are no longer there. Link to comment Share on other sites More sharing options...
Paul Bruchal Posted January 19, 2012 Author Share Posted January 19, 2012 I looked at mine again today and whats being cut isnt a e brake cable, its me rear break cable... spraying brake fluid on my diff.={ Whats the large piece of metal with a lever on it mounted on top of my axle that attaches to the bed? thats what cut my hose Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 20, 2012 Share Posted January 20, 2012 you mean this? its the height sensor Link to comment Share on other sites More sharing options...
comanche12 Posted January 20, 2012 Share Posted January 20, 2012 I would remove that part out if its leaking. There DIY topic on it. Link to comment Share on other sites More sharing options...
Paul Bruchal Posted January 20, 2012 Author Share Posted January 20, 2012 Yes, The height sensor. I couldn't remember that name for a mill $. A DIY post on removing it? Then I'm guessing I don't "need" it. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 20, 2012 Share Posted January 20, 2012 you can replace it with one from a XJ or ZJ.. the front prop valve will need the bypass line to be plugged or replaced with the XJ or ZJ. that is what that diagram on the first page was for. Link to comment Share on other sites More sharing options...
