4wd bracket on the Cherokee?
I installed the trans and transfer case from a 99 Cherokee into my 88 Comanche. All is good, except one thing. On the transfer case shifter linkage, it looks like there was a bracket for the pivot bar to go in, that was on the transmission tunnel of the donor Jeep.I never sw it though. Does anyone know a source for these, or have a diagram so I can fab it? It is triangle shaped, with bolt holes in the top, a larger hole to hold the bar in the bottom, and the top half inch would be angled.
