Will XJ rubber door weatherstripping fit MJs?
For one even thicker than the 97+ look for the door seal from a ZJ, they're thicker and slightly longer so will require trimming.
Thicker than the 97+? Do you have to slam the door closed? :D
Have you actually done this, or are you just assuming it will work?
It's a common replacement for the XJ guys through all ranges. The moulding from all doors and hatch from the grands will fit when cut down slightly. So since it works for the xj's and the fronts are the same as the MJ's it would provide even better sealing.
