njcomanche1227 Posted December 12, 2011 Share Posted December 12, 2011 i just bought a 87 mj. the key i got works for the ignition but not for the locks on the doors Should i just replace the whole locking mechanism altogether or can i some how get a key made? Link to comment Share on other sites More sharing options...
jimoshel Posted December 12, 2011 Share Posted December 12, 2011 Any good locksmith can make a key. Either remove the lock cylinder and take it to one or take the truck to one and have him work in the parking. Might want to call a couple and compare prices. Link to comment Share on other sites More sharing options...
carnuck Posted December 12, 2011 Share Posted December 12, 2011 Passenger's side has a code for the key Link to comment Share on other sites More sharing options...
Eagle Posted December 13, 2011 Share Posted December 13, 2011 On the 87s (and 88s and 89s and 90s) the ignition key is a 6-bit key and the door keys are 5-bit keys. It is not possible to make a key that will operate the ignition and the doors. Those years were two-key years and there's no easy way around it. If you remove the door cylinders and take them to a locksmith, he can easily make new keys to work those locks, but they won't be the same as the ignition key. Link to comment Share on other sites More sharing options...
njcomanche1227 Posted December 13, 2011 Author Share Posted December 13, 2011 thanks for the advice guys Link to comment Share on other sites More sharing options...
specialkeay Posted December 13, 2011 Share Posted December 13, 2011 If your going threw the trouble to take out the key cylinder then you might as well get another set from a junk yard of a cherokee, its going to be cheaper with a touch more labor but worth it. I did mine last week, I took the lock cylinders from a 96 cherokee and put them in my 89 MJ (make sure you get a jeep with the keys in it). Nothing wrong with have two keys for my MJ now I can finally lock it. Link to comment Share on other sites More sharing options...
Boots Posted December 14, 2011 Share Posted December 14, 2011 When I first got mine I was planning on having to get a new door key made since it didn't come with one. :fs2: Then I found a hide-a-key under the bumper. :yes: Link to comment Share on other sites More sharing options...
carnuck Posted December 22, 2011 Share Posted December 22, 2011 To get the code, you pop the lock loose on the passenger's side (pull the clip holding it in) tip it out and write down the code, then put it right back. Doesn't take long. Link to comment Share on other sites More sharing options...
