Failed weld on clutch pedal
Soo... I must have the worst karma ever. :wall:
Just a month after a full slave / master replacement, my actual clutch pedal failed. I'm sorry I don't have pics, but the weld failed right up at the pivot point the first time I depressed the pedal this morning.
Does anyone know if this is weldable, or even should be welded? Should I be buying a replacement pedal assembly instead?
Thanks in advance for the help.
Boy, that is some rotten luck!!
My thinking is that, if it was welded originally
it should be weldable again, but you may also
consider grabbing one from the JY instead.
Would be interesting to see that failed weld under
a microscope.
I had the same problem with my 88 Pioneer years ago. Had a friend who was good with a stick welder fire glue it back together in situ. I have not had a problem with it since. I would suggest taking the time to find someone who is a competent welder.
