Joop Posted November 12, 2011 Posted November 12, 2011 Here's the pictures i promised you! Found this pic online, this should clear a 4.0 Then i snapped a pic of one of mine, this one will not clear a 4.0. The difference is in the area above the transmission tunnel. And finally a closep of how i made it fit in my other 86 using a BFH. I got about 1/4" clearance between the exhaus and the firewall, not quite as much as i would like but it works. This is how i made the radiator fit And a crappy pic of how i solved the crossmember problem, this is the drivers side. It needs to be moved about 4" back and nothing is bolt on. I drilled holes straight trough the frame for the outher bolts (fully welded to the frame on both sides) and one of the inner bolts on each side i fixed to the original bracket. The inner-rear bolt on each side has nothing to bolt to, but it should be enough with just 3 bolts on each side. XJ's use only 2 after all. This is about the only fabrications that has to be done, exept from shortening your rear driveshaft. The rest is just pain-in-the-@$$ wiring. Btw, keep your original 4.10 axles. Mpg increase, if you actually get any, will not be worth the extra work. And its much more fun to drive!
Pete M Posted November 12, 2011 Posted November 12, 2011 if mpgs are important to you, don't lift it 6". and you might even see a bump up in city mpgs with the 4.10s and stock tires. the deeper gears will help you get going off the line. and if you go with 31s, you'll definitely want those 4.10s. are both vehicles 4x4s?
mpace6a Posted November 12, 2011 Author Posted November 12, 2011 Yea, the xj and mj are both 4x4 -Matt
Pete M Posted November 12, 2011 Posted November 12, 2011 then I would definitely keep the 4.10 axles under the MJ. try it. you just might be happy and it'll get the truck up and running that much faster. :thumbsup: have you checked that they are indeed 4.10s?
mpace6a Posted November 12, 2011 Author Posted November 12, 2011 No, thats just what the PO said. Ive been more interested in gettin it running so dad can have his truck back and i can have my much missed 4x4!
Pete M Posted November 13, 2011 Posted November 13, 2011 quick-n-dirty way to check: -jack up one of the rear tires -put trans in neutral -rotate tire around exactly twice while counting the number of times the driveshaft rotates -if the driveshaft rotates 3 and a half times, it'll be 3.55... if it's just over 4 times: 4.10... etc. if the rear axle has a posi, you'll need to jack up both rear tires and then rotate only once around. :thumbsup:
mpace6a Posted November 18, 2011 Author Posted November 18, 2011 Well as near as I can tell with that v6 in the way, I am going to have to show the firewall some love :wall: But aside from that i think (hope) everything will fit alright. Tearin into the mj tomorrow after school, and going to start going through the 4.0 more thoroughly. There'll be a build thread posted, since i figure thats a better way to keep track of whats going on with it. I'll be sure to take lots of pics, because i know i'll need lots of help :shake:
onlyinajeep726 Posted July 12, 2013 Posted July 12, 2013 Can I see some of these pictures? :brows: I'm starting this swap and anything that I can reference will be greatly appreciated. :yes:
mpace6a Posted July 14, 2013 Author Posted July 14, 2013 Holy thread revival... Didnt end up doing the 4.0 swap, decided that, for the labor involved, I'd rather put in a small block or a diesel, so my mj is just putting around with a tbi block 2.8 that I carb'd. Runs alright.
onlyinajeep726 Posted July 14, 2013 Posted July 14, 2013 Yea, I know it's an old thread.. Just wasn't sure if you had some relevant pictures to aid in my "4.0 in an '86" swap lol. I've become the dead thread revival king lately.
mpace6a Posted July 14, 2013 Author Posted July 14, 2013 Yea, I know it's an old thread.. Just wasn't sure if you had some relevant pictures to aid in my "4.0 in an '86" swap lol. I've become the dead thread revival king lately. don't really think I do...but if your feeling adventurous feel free to browse my photobucket. May have something you can use?
onlyinajeep726 Posted July 14, 2013 Posted July 14, 2013 Thanks buddy! I'll check it out later and see what I can find.
