Ok. 1986 2.5l comanche. I checked my oil last night and found milky white on the top and half way down the dipstick, bottom of the dipstick seems normal. What would cause this? I drive it 60+ miles aday so its not like it sits of days
Sorry posting from wifes smarty phone
Kendal oil will cause that
Can you take a picture? It sounds like you are saying the oil level check portion of the dipstick is normal while there is a spot of milky oil part way up the dipstick away from the level check. If this is the case, I would not rule out condensation. Drain your oil and report back to us with what is in the pan.
wow was just little drunk when i posted that :cheers:
anyways its just milky on the top 6 inch or so of the dip stick, then its normal down to the oil fill level.
Drained oil and nothing in the oil, was normal other then reallllllly black.
ran 4 qts of atf for 15min and drained, black agian
full tune up on her and she runs like a top.
