SGTJHALL Posted October 13, 2011 Share Posted October 13, 2011 I was wondering what MODS are needed for my project. I have a 86 comanche longbed and I'm in the process of swapping out the 2.8 V6 for the Inline 6 4.0 out of a 92 Cherokee. The comanche already has a SOA Lift done to the rear end, which I believe is about makes it about a 4.5 inch lift. I have read that you have to shorten the rear driveshaft to make the swap work because the stock driveshaft is to long. Is this true with a SOA lift, and if so can I find a driveshaft of a comanche longbed that came stock with the inline 6 4.0 and would this fix the issue. Or will the cherokee driveshaft work with the SOA Lift or will my stock comanche driveshaft work with the SOA Lift? I appreciate any help, if nothing above will work does anyone know how I can fix this issue, its really the only thing I need to figure out to be able to get started on the swap and know for sure I can complete it without any issues. I'm trying to stay away from welding, so if I will still have to shorten the stock driveshaft is there anywhere I can by a new driveshaft specifically for such a project. Link to comment Share on other sites More sharing options...
87Warrior Posted October 13, 2011 Share Posted October 13, 2011 Your best bet is to get everything swapped in then measure for your driveshaft. There is a good chance you will have something that will work, but if not, you can get one lengthened or shortened by a drive line shop. Link to comment Share on other sites More sharing options...
Pete M Posted October 13, 2011 Share Posted October 13, 2011 we have some stock driveshaft measurements in a thread in the DIY forum. :thumbsup: XJs have a foot less wheelbase than a shortbed MJ (add another 6" for a longbed) and so their rear shafts are too short to use as-is. Link to comment Share on other sites More sharing options...
kyleag89 Posted October 14, 2011 Share Posted October 14, 2011 I'm not 100% positive but wouldn't lifting(SOA) require the drive shaft to be longer not shorter? Link to comment Share on other sites More sharing options...
87Warrior Posted October 14, 2011 Share Posted October 14, 2011 I'm not 100% positive but wouldn't lifting(SOA) require the drive shaft to be longer not shorter? Typically, yes. But he is installing a longer drivetrain. Link to comment Share on other sites More sharing options...
Jeep Driver Posted October 14, 2011 Share Posted October 14, 2011 I was wondering what MODS are needed for my project. I have a 86 comanche longbed and I'm in the process of swapping out the 2.8 V6 for the Inline 6 4.0 out of a 92 Cherokee. The comanche already has a SOA Lift done to the rear end, which I believe is about makes it about a 4.5 inch lift. I have read that you have to shorten the rear driveshaft to make the swap work because the stock driveshaft is to long. Is this true with a SOA lift, and if so can I find a driveshaft of a comanche longbed that came stock with the inline 6 4.0 and would this fix the issue. Or will the cherokee driveshaft work with the SOA Lift or will my stock comanche driveshaft work with the SOA Lift? I appreciate any help, if nothing above will work does anyone know how I can fix this issue, its really the only thing I need to figure out to be able to get started on the swap and know for sure I can complete it without any issues. I'm trying to stay away from welding, so if I will still have to shorten the stock driveshaft is there anywhere I can by a new driveshaft specifically for such a project. If you have the large diameter tube-n-tube shaft........my drive shop refused to shorten it. I had them make up a new 3" shaft. They also would not use the shaft from a XJ as they said it was too small in diameter for a truck and there was a good chance I'd wring the shaft under load. Cost me $225 and they only used my yoke......the rest was new and all Spicer parts. And what a difference.......smooth, very smooth. Link to comment Share on other sites More sharing options...
SGTJHALL Posted October 14, 2011 Author Share Posted October 14, 2011 lsmurphy The info was very helpful and much appreciated. Its good to know it won't be to expensive, this issue has been holding up my build for the last 2 weeks so thank you! I will let you know how things go after I get the work done! Link to comment Share on other sites More sharing options...
