drcomanche Posted August 21, 2011 Share Posted August 21, 2011 So, I have a Ford 9 inch rear with to be 5 lug hubs and disc brakes. The calipers have absolutely no e brake assembly on them, and I've been thinking about adding them for a while. So, what would be the best method for putting an e brake onto it? Are there any calipers or whole brake assemblies that will fit on the axle from a donor vehicle? Link to comment Share on other sites More sharing options...
cz777 Posted August 22, 2011 Share Posted August 22, 2011 don't the ford use the inside of the disc hub -mini drum brakes? or like jag xj-6 style ? both can work but this means some work and mods ! oh yes its a jeep thing,lesson learned ! Link to comment Share on other sites More sharing options...
drcomanche Posted August 22, 2011 Author Share Posted August 22, 2011 When did Ford start using those? And on what vehicles? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 22, 2011 Share Posted August 22, 2011 Explorers among others. Link to comment Share on other sites More sharing options...
XxStirCrazedxX Posted August 22, 2011 Share Posted August 22, 2011 76-78 cadillac eldo will work. From what i understand you need to use the ebrake offten so they stay adjusted. i have never used them, but was looking up some info for a hotrod project. hope this helps Link to comment Share on other sites More sharing options...
87Warrior Posted August 22, 2011 Share Posted August 22, 2011 I am not sure if this is true, but my buddy was telling me some of the newer Mustangs have an e-brake set up that actually twists the caliper/pads into the rotor. I would imagine something like that would be easier to adapt than the drum-in-hat e-brake system. Link to comment Share on other sites More sharing options...
XxStirCrazedxX Posted August 22, 2011 Share Posted August 22, 2011 the cadi ones use a lever and spring to clamp the pads on the rotor. :cheers: Link to comment Share on other sites More sharing options...
