m0brando Posted December 20, 2005 Posted December 20, 2005 Finally settled on a '92 Comanche and now i'm in the dreaming stage! It has a broken-down bench and I was initially thinking of doing XJ buckets. However I have 2 small children and if I do that I'll never be able to take them both even though this is a 3rd vehicle and doesn't really need to. Has anyone researched adding a bench with an armrest or a 60/40 similar to what's in late model Ranger's, etc? I did a search but didn't find any chatter about using non-Jeep seats. thanks! Brandon '97 XJ '92 MJ '84 CJ8 Various other *J's!
DirtyComanche Posted December 20, 2005 Posted December 20, 2005 If I was you, I'd go to a pick'n'pull with a couple wrenches and a tape measure. Find something you like, sit in a it, measure everything that looks critical to see if it's going to fit at all, and pull it if it'll work. Summit Racing sells universal seat mouting brackets, which will probably work. Or you could just steal the brackets off your origonal bench seat and fab up whatever you'll need to make them work. I doubt that would be hard as all you'll need, most likely, is some peices of bar stock and a couple bolts/nuts. I'm just saying this because I don't think anybody has done the swap. I put buckets in mine.
Bounty Hunter Posted December 21, 2005 Posted December 21, 2005 I'd like to swap a bench into mine for the same reason, and adding a center belt. Don't see swapping that direction very often.
mjeff87 Posted December 21, 2005 Posted December 21, 2005 Wonder if an earlier model Dakota bench would fit? Might have to take some measurements next time I'm at the 'yard.. Jeff
JPinnell Posted December 21, 2005 Posted December 21, 2005 Get a late '90s to early 2000 Ranger 60/40 Bench. My folks have a 2001 Ranger Extra Cab and I've measured the seat. It looks to be the exact width, height, length, etc. and it even has a cutout for the shifter. I did have a '96 Dakota and the bench in it was bigger than the MJ. I plan to hit the yards this Spring and swap it in instead of my current bench. - JP
