drcomanche Posted August 3, 2011 Share Posted August 3, 2011 So, as the name implies, my speedometer isn't working. I looked under the truck at the tranny and it seems that there is absolutely no connection to the speedometer gear underneath but it seems to be a wire connection. Where does it connect to? I'm unsure about this because I have a transplant engine and transmission on the truck, and it came from a later year xj. It has a full gauge cluster on it, but I always remember it being a cable attachment and not a wire... Link to comment Share on other sites More sharing options...
jimoshel Posted August 3, 2011 Share Posted August 3, 2011 The '88 uses a flexible cable to connect the output of the tran to the speedo. The '94 uses an electronic system. Remove the sending unit from the tran. Replace it with one from a '84-89. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted August 3, 2011 Share Posted August 3, 2011 My cable (88) got yanked out of the little key on the speedo gear in the transfer case when I was working on the gauge cluster. I just grabbed the tip with some needle nosers and carefully worked the square end back into the square hole, didn't have to replace cable or gear.. :clapping: Link to comment Share on other sites More sharing options...
bigalpha Posted August 4, 2011 Share Posted August 4, 2011 On a related note, are the cables from the MJ and XJ the same length? Link to comment Share on other sites More sharing options...
ParadiseMJ Posted August 5, 2011 Share Posted August 5, 2011 :dunno: Link to comment Share on other sites More sharing options...
FrankTheDog Posted August 5, 2011 Share Posted August 5, 2011 On a related note, are the cables from the MJ and XJ the same length? Yes, they are. The drivetrains are the same length and same position in the chassis. Link to comment Share on other sites More sharing options...
bigalpha Posted August 5, 2011 Share Posted August 5, 2011 On a related note, are the cables from the MJ and XJ the same length? Yes, they are. The drivetrains are the same length and same position in the chassis. Gratzi. Link to comment Share on other sites More sharing options...
Geonovast Posted August 5, 2011 Share Posted August 5, 2011 On a related note, are the cables from the MJ and XJ the same length? Yes, but 2wd and 4wd cables are not the same length. 2.5 cables may also be different lengths, and there's also the differences between cruise and non-cruise cables. You're looking at 4-8 different cables, so try to get as close as you can when you get a replacement. Link to comment Share on other sites More sharing options...
bigalpha Posted August 5, 2011 Share Posted August 5, 2011 On a related note, are the cables from the MJ and XJ the same length? Yes, but 2wd and 4wd cables are not the same length. 2.5 cables may also be different lengths, and there's also the differences between cruise and non-cruise cables. You're looking at 4-8 different cables, so try to get as close as you can when you get a replacement. I definitely pulled a cabled from a similarly equipped XJ (2WD, AW4, 4.0L). Link to comment Share on other sites More sharing options...
