Need Renix 4.0l 5spd harness
mnkyboy
I have an 89MJ,the engine is from a 90 XJ
I have a set from an '88. I hear there are differences. Unless someone confirms otherwise, then I think you need to match year to year. I don't think the motor changed much if any from 87 to 90.
Also the other posters price if very good. Same year as yours. I'd probably snag it.
Tom
AFAIK, the only difference between 87-90 harnesses is that the 87 might not have a ballast resistor. Also, again not 100% on this, but I think that the XJ and the MJ used different firewall plugs to connect to the dash harness.
