I bought a set of injectors from precisionautoinjectors.com and they have blue plastic tips. Are they protective caps that require removal or do I just install as is? I've tried contacting them but they don't reply.
they are called pintle caps.used to you could buy replacement ones(maybe you still can)if they became hard and brittle and cracked or crumbled when removed.they do need to be on there.
