bent mine on a stump the other day. i know about the zj stuff being a good upgrade and i can easily fix this one or replace it with an xj one, but I'm quite pressed for time these days and would like to know if i can just grab a zj one and have it be a simple direct bolt-on?
thanks, shawn.
Should bolt straight in. If it's a different diameter, you'll need to grab the bushings that go with it where it bolts to the frame.
I don't think he means sway bar. But the tie rod should be a direct bolt in, yes, then do a quick alignment.
Whoa... no idea how I misread that. Not quite awake over here, apparently.
Don't know if the TREs are different or not, but the ZJ TREs should go into the XJ knuckle/draglink just fine.
