fiatslug87 Posted July 4, 2011 Posted July 4, 2011 I'm adding a Blackjack header to my '88 4.0, but the EGR tube will not match up. I took a section out of the middle, cut another pipe to use as a sleeve for the cut ends and need to weld it in place. I only have a small O2/MAPP gas set up and was wondering if JB Weld would work instead. They fit pretty tight and the pieces overlap by at least 3/4 of an inch. Deleting the tube is not an option, CA smog inspections.
jimoshel Posted July 4, 2011 Posted July 4, 2011 Don't see why not. Make sure the surface is clean and roughed up a bit with a Brillo pad or fine sand paper.
fiatslug87 Posted July 6, 2011 Author Posted July 6, 2011 Don't see why not. Just asking because their web site says up to 500 degrees and not recommended for exhaust. I don't know how hot the EGR tube gets.
Automan2164 Posted July 6, 2011 Posted July 6, 2011 Pretty freaking hot. And if it specifies not to use on exhaust right on it... Why are we here? :D Get it placed how you want it, and have the local muffler guy weld it up for you. Toss him a 10, and forget about it. Rob :cheers:
HOrnbrod Posted July 6, 2011 Posted July 6, 2011 I agree - JB Weld won't hold for long. I'd get it brazed or if you have a torch, silver solder it. Either way will work and last.
fiatslug87 Posted July 11, 2011 Author Posted July 11, 2011 Thanks guys, I ended up using my O2/MAPP set up and brazing it together.
64 Cheyenne Posted July 11, 2011 Posted July 11, 2011 :agree: This is the kind of stuff I like to see, a question asked, then going out and making the tougher fix work. Cool
mjtjnj Posted July 11, 2011 Posted July 11, 2011 Nice work! Easier off the car. FWIW, I tried the JW and it failed, miserably, after I put my header on. You had a lot of room to work! After mine failed, I got some stainless steel flexible tube from a source (exhaust for gas powered model airplanes) and clamped it on both sides. Worked well. Really annoying exhaust leak from the rigged tubes.
fiatslug87 Posted July 11, 2011 Author Posted July 11, 2011 Thanks for flexible tube source. I was the picture of safety :nuts: :t-shirt, shorts, sandals in the bed of one MJ under a tarp (had to block the wind), but I did have my mask on :thumbsup:
