mj Mike Posted June 22, 2011 Share Posted June 22, 2011 Any of you ever have this problem with the Comanche? :hmm: My red 90 Cherokee has this problem it comes & goes but most of the time i have Solid blinkers? :dunno: Link to comment Share on other sites More sharing options...
zagscrawler Posted June 22, 2011 Share Posted June 22, 2011 i have yet to explore this in a comanche but i would say its as simple as a flasher. The flasher usually kills the power to the lights as they heat up and sometimes redirects the power depending on the flasher and truck. It gets hot and kills power, when it cools it completes the conection and lights up again. If it is stuck on it will light up solid. Not sure if this applies to the jeeps but old school flashers work like this. Do you hear any clicking when you apply the signals? Is your indicator light solid as well? The clicking is the relay snaping forward and back. If you do hear the clicking and it is still solid then they probably have some sort of brake switch interupt which gets a little bit more tricky. Hope this helps Link to comment Share on other sites More sharing options...
mj Mike Posted June 22, 2011 Author Share Posted June 22, 2011 I do Not hear any clicking when you apply the signals & yes my indicator lights are solid as well. :( Thanks! I will try swaping in a new flasher relay. :idea: Link to comment Share on other sites More sharing options...
dasbulliwagen Posted June 22, 2011 Share Posted June 22, 2011 You have a turn signal flasher and a 4 way flasher, just swap them for a quick and easy diagnosis. That is assuming your 4 ways work. My boss's MJ did this and it was the flasher. When you go to get a new flasher, get a heavy duty one made for towing. That type doesnt rely on the heat up shut off method to flash... if it did when you add a trailer, it would change the speed the lights flash. The heavy duty one use a different method and flash the same speed all the time, that is likely the type that is in the 4 way side already! Good luck. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 22, 2011 Share Posted June 22, 2011 Lower left - blinkers Upper right - emerg. flashers When my blinkers indicators were always on I checked the sockets. I was able to clean the rears up but the 2 in front were toast. I replaced the sockets, now all good. Link to comment Share on other sites More sharing options...
mj Mike Posted June 23, 2011 Author Share Posted June 23, 2011 Got it! thanks All for the good info :smart: I just swap them from my other jeep for a quick and easy diagnosis & the blinkers relay was out :cheers: Link to comment Share on other sites More sharing options...
kawaboy13 Posted July 9, 2011 Share Posted July 9, 2011 Mine won't blink in the front when my lights are on :dunno: Link to comment Share on other sites More sharing options...
Eagle Posted July 9, 2011 Share Posted July 9, 2011 Mine won't blink in the front when my lights are on :dunno: Bad ground, or bad sockets. Replace the sockets. The chain auto parts places have a replacement socket on the HELP! pegboard that fits perfectly, although the application it's listed for is a Ford. Take an old socket with you to match it up. Link to comment Share on other sites More sharing options...
