The "school me on Renix alternators" thread.
Looks like there are two case sizes for replacement renix alternators:
130mm (5 1/8 in.) Diameter Case
121mm (4 3/4 in.) Diameter Case
Small case alts seem to be the 61a versions,
large case either 85a, or 100a.
Questions,
were both sizes original equipment on Renix 4.0L's?
is there a specific mount bracket for the 130mm vs 121mm, or will either alternator fit either mount?
Simple questions, I know,
but the last time I bought a new Renix alternator, they were an on the shelf item for a 5-6 year old vehicle.
Now they are special order parts for 20 year old dinosaurs,
and I don't want to order the wrong one. :doh:
The small case alternator is for non A/C trucks not equipped with HD cooling. The large case alternator is for all others. The larger alternator is a direct bolt-in replacement for the non A/C (non HD cooling) alternator though I did have to pry the U bracket open just a bit wider (1/4" or so) to fit it in.
As a bonus the bigger case/higher output alternators are cheaper than the small case ones :clapping:
Not only was it an upgrade but it was cheaper. How cool is that :)
Thanks guys!
Keep the info coming if anyone has anything else to add.
I'll order the bigger one, and figure I may have to tweak the mount a bit,
I'm just hoping they still come with the pulley.
I don't know anything about the difference in alt. sizes, but when I replaced mine on my non-ac non-e-fan truck I got the 110 (I think, the highest one available) amp and it fit in no problem
